Salta al contenuto principale
Lenovo Ideapad S415 Touch RAM Replacement
Alexandria
Alexandria e 2 altri collaboratori
Ultimo aggiornamento il June 14, 2019
10 - 20 minuti
Moderato
Introduzione
Vai al passo 1
If your laptop is running out of space and starts getting slow, there may be a problem with your RAM. This guide will help replace the RAM in your laptop.
In order to replace the RAM you will first need to remove the battery. Make sure you have a Phillips #0 screw bit or screwdriver on hand. Be careful when dealing with the RAM. When removing it, take extra care not to touch the yellow strip on top of the RAM because the oil from fingers can damage the piece.
Cosa ti serve
  1. Lenovo Ideapad S415 Touch RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Flip laptop over bottom side up.
    • Locate the two battery release switches.
  2. Lenovo Ideapad S415 Touch RAM Replacement: passo 2, immagine 1 di 1
    • Use your finger to push the battery release switch labeled "1." The red indicates that the switch is unlocked.
  3. Lenovo Ideapad S415 Touch RAM Replacement: passo 3, immagine 1 di 1
    • Use your finger to push the battery switch labeled "2."
  4. Lenovo Ideapad S415 Touch RAM Replacement: passo 4, immagine 1 di 1
    • Once both switches are unlocked, the battery will release.
  5. Lenovo Ideapad S415 Touch RAM Replacement: passo 5, immagine 1 di 1
    • When replacing the battery make sure the two protruding holes line up with the slot.
    • Carefully remove the battery.
  6. Lenovo Ideapad S415 Touch RAM Replacement, RAM: passo 6, immagine 1 di 2 Lenovo Ideapad S415 Touch RAM Replacement, RAM: passo 6, immagine 2 di 2
    • Locate the five 6mm black screws on the bottom.
    • Using a Phillips #0 screwdriver, remove all five screws.
  7. Lenovo Ideapad S415 Touch RAM Replacement: passo 7, immagine 1 di 2 Lenovo Ideapad S415 Touch RAM Replacement: passo 7, immagine 2 di 2
    • Locate the three 4mm silver screws on the bottom area where the battery was removed.
    • Use the Phillips #0 screwdriver to remove all three screws.
  8. Lenovo Ideapad S415 Touch RAM Replacement: passo 8, immagine 1 di 3 Lenovo Ideapad S415 Touch RAM Replacement: passo 8, immagine 2 di 3 Lenovo Ideapad S415 Touch RAM Replacement: passo 8, immagine 3 di 3
    • Locate the four rubber stoppers near each corner of the laptop.
    • Open up the stoppers by lifting each with your hands.
  9. Lenovo Ideapad S415 Touch RAM Replacement: passo 9, immagine 1 di 3 Lenovo Ideapad S415 Touch RAM Replacement: passo 9, immagine 2 di 3 Lenovo Ideapad S415 Touch RAM Replacement: passo 9, immagine 3 di 3
    • Under each of the four stoppers, there will be a 6mm screw.
    • Use the Phillips #0 screwdriver to remove all four screws.
  10. Lenovo Ideapad S415 Touch RAM Replacement: passo 10, immagine 1 di 2 Lenovo Ideapad S415 Touch RAM Replacement: passo 10, immagine 2 di 2
    • Carefully open up the laptop to reveal the internal components.
  11. Lenovo Ideapad S415 Touch RAM Replacement: passo 11, immagine 1 di 3 Lenovo Ideapad S415 Touch RAM Replacement: passo 11, immagine 2 di 3 Lenovo Ideapad S415 Touch RAM Replacement: passo 11, immagine 3 di 3
    • Locate the RAM.
    • Using your hands gently push up on the two silver clips located on both ends of the RAM.
    • The RAM will spring out. Gently pull it out of the slot.
    • Do not touch the top yellow part of the RAM as this will cause damage.
Conclusione
Alexandria
Membro da: 02/05/19
363 Reputazione
2 Guide realizzate
UC Davis, Team S20-G5, Lore Winter 2019 Membro di UC Davis, Team S20-G5, Lore Winter 2019
UCD-LORE-W19S20G5
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 824
