Salta al contenuto principale
Lenovo Ideapad S415 Touch Battery Replacement
Casey Zhang
Casey Zhang e un altro collaboratore
Ultimo aggiornamento il June 13, 2019
2 minuti
Molto facile
Introduzione
Vai al passo 1
If you are having trouble with your computer's battery life, or if your computer will not power on, this is the guide to help solve your problems. There are no tools needed to perform any steps, but be careful in putting the battery back into the laptop.
  1. Lenovo Ideapad S415 Touch Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Flip laptop over bottom side up.
    • Locate the two battery release switches.
  2. Lenovo Ideapad S415 Touch Battery Replacement: passo 2, immagine 1 di 1
    • Use your finger to push the battery release switch labeled "1." The red indicates that the switch is unlocked.
  3. Lenovo Ideapad S415 Touch Battery Replacement: passo 3, immagine 1 di 1
    • Use your finger to push the battery switch labeled "2."
  4. Lenovo Ideapad S415 Touch Battery Replacement: passo 4, immagine 1 di 1
    • Once both switches are unlocked, the battery will release.
  5. Lenovo Ideapad S415 Touch Battery Replacement: passo 5, immagine 1 di 1
    • When replacing the battery make sure the two protruding holes line up with the slot.
    • Carefully remove the battery.
Conclusione
Casey Zhang
Membro da: 02/06/19
315 Reputazione
2 Guide realizzate
UC Davis, Team S20-G5, Lore Winter 2019 Membro di UC Davis, Team S20-G5, Lore Winter 2019
UCD-LORE-W19S20G5
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 12
Tutti i Tempi: 328
