Salta al contenuto principale
Lenovo IdeaPad 330S RAM Replacement
Ilia Tocheny
Ilia Tocheny e un altro collaboratore
Ultimo aggiornamento il March 15, 2023
5 - 20 minuti
Moderato
Guida fornita dalla comunità
Introduzione
Vai al passo 1
You may find yourself in need of additional memory to feed hungry computer applications such as graphics and video editing tools. If you would like to replace a faulty RAM stick or one with insufficient capacity, follow this guide.
The battery for this device is not easily accessible and will require opening the device. Before you begin your replacement, be sure to disconnect the laptop from any power source. Additionally, we recommend that you turn off the device wait 5 minutes.
If you live in area rich of Static Electricity please advise using an ESD Strap.
Cosa ti serve
Strumenti
Mostra di più…
  1. Lenovo IdeaPad 330S RAM Replacement, Removing bottom case: passo 1, immagine 1 di 2 Lenovo IdeaPad 330S RAM Replacement, Removing bottom case: passo 1, immagine 2 di 2
    • Please turn off the laptop before opening the device
    • Remove the 10 screws as shown in the picture.
    • Gently using the tool pry off the bottom case
  2. Lenovo IdeaPad 330S RAM Replacement, Disconnecting Battery: passo 2, immagine 1 di 1
    • Using a spudger gently push the plastic connector to the left in order to disconnect the battery. wisdom here.
  3. Lenovo IdeaPad 330S RAM Replacement, Removing Black Case: passo 3, immagine 1 di 2 Lenovo IdeaPad 330S RAM Replacement, Removing Black Case: passo 3, immagine 2 di 2
    • Remove these screws as show in picture
    • Gently pry out the black case.
    • Note that one of the screws are Philips 2.5 and not Philips (the black screw top right ).
    Before removing the case, for safety you have to disconnect the battery cable, otherwise you may damage the motherboard when you touch it with the case.
    Gastón Luna - Replica
    Thank you for reminding it. The repair guide have been updated.
    Ilia Tocheny - Replica
    In my case - only 3 screws have to be removed. The top screw is under cover and no need to remove it. Lenovo 330s-15lkb
    Сергей Шацкий - Replica
  4. Lenovo IdeaPad 330S RAM Replacement, Removing Ram Stick: passo 4, immagine 1 di 1
    • Gently using heavy duty spuder remove the old memory
    If you dont have a heavy duty spudger you could use your nails to remove the memory module.
  5. Lenovo IdeaPad 330S RAM Replacement, Installing Ram Stick: passo 5, immagine 1 di 1
    • Arrange the new ram stick accoring the pin on the motherboard
    • Push Gently on the stick until you hear two clicks
Conclusione
To reassemble the device, install your new stick(s) and follow these instructions in reverse order.
Altre 6 persone hanno completato questa guida.
Ilia Tocheny
Membro da: 04/30/19
1.667 Reputazione
9 Guide realizzate
8Commenti sulla guida
Is it possible to upgrade the cpu of my lenovo 330s which is a core i3 7gen to say a core i5 10th gen
Nathan D'souza - Replica
Only by replacement or the Motherboard…
The CPU is soldered to the M.B. and cannot upgraded easily
Hallo.
I am Japanese Hegt Stuident.
Do I need to remove the battery when removing the RAM?
(こんにちは。
日本の高校生です。
RAMを外すとき、バッテリーは外す必要がありますか?)
Muromi - Replica
You can disconnect the battery no need of removing it.
Ilia Tocheny -
I just Updated the repair guide of memory replacement.
I think I can do it well. Thank you.
Muromi - Replica
Brilliant guide! The black case covering my RAM module was slightly different but the principle is the same. Thanks for stating the tools needed and having clear pictures and easy-to-follow instructions!
jaron84 - Replica
Thank you for the support. my ideapad 330S originally was i5 8520U and got upgraded on warranty to an i7 8550U. so basically there are not that different…
Ilia Tocheny -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 96
Tutti i Tempi: 8,275
