Salta al contenuto principale
Lenovo 100s Chromebook-11IBY Webcam Replacement
Milton Perez
Milton Perez e un altro collaboratore
Ultimo aggiornamento il December 15, 2019
6 - 9 minuti
Moderato
Introduzione
Vai al passo 1
This guide will show how to remove the webcam for the Lenovo 100s Chromebook-11IBY. This removal will allow you to replace or upgrade the webcam for your laptop.
Cosa ti serve
Strumenti
  1. Lenovo 100s Chromebook-11IBY Webcam Replacement, Webcam: passo 1, immagine 1 di 1
    • Ensure your device is turned off and unplugged.
  2. Lenovo 100s Chromebook-11IBY Webcam Replacement: passo 2, immagine 1 di 1
    • Use the plastic opening tool on the recessed notch to gently pry each side of around the screen up.
  3. Lenovo 100s Chromebook-11IBY Webcam Replacement: passo 3, immagine 1 di 2 Lenovo 100s Chromebook-11IBY Webcam Replacement: passo 3, immagine 2 di 2
    • Carefully pry up and underneath both the (left & right) hinges of the screen cover.
  4. Lenovo 100s Chromebook-11IBY Webcam Replacement: passo 4, immagine 1 di 2 Lenovo 100s Chromebook-11IBY Webcam Replacement: passo 4, immagine 2 di 2
    • Use the plastic opening tool on the inside of the screen plate and again on the sides to gently remove it.
  5. Lenovo 100s Chromebook-11IBY Webcam Replacement: passo 5, immagine 1 di 1
    • Gently unplug the wire connecting the webcam to the laptop.
  6. Lenovo 100s Chromebook-11IBY Webcam Replacement: passo 6, immagine 1 di 2 Lenovo 100s Chromebook-11IBY Webcam Replacement: passo 6, immagine 2 di 2
    • Using the plastic opening tool, gently lift the webcam panel from the screen. Then remove it.
Conclusione
USF Tampa, Team S7-G2, Cagle Spring 2017 Membro di USF Tampa, Team S7-G2, Cagle Spring 2017
USFT-CAGLE-S17S7G2
1 Membro
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 356
