Salta al contenuto principale
Land Yachtz Longboard Kingpin Replacement
Max Badal
Max Badal e 2 altri collaboratori
Ultimo aggiornamento il June 8, 2023
15 - 25 minuti
Moderato
Introduzione
Vai al passo 1
If your Land Yachtz longboard isn't turning well or you find that you can't adjust the tension of your trucks, your board kingpin may be damaged or faulty. Use this guide to replace the faulty kingpin and get your board back into good shape.
The kingpin is essential in turning the board with your body weight and allowing the user to effectively control their movement. If it is faulty, the board will not do its job and injury can result.
This ten-step guide will show you how to replace the kingpin without potentially damaging other parts of the longboard and allow for a better ride.
  1. Land Yachtz Longboard Kingpin Replacement, Kingpin: passo 1, immagine 1 di 3 Land Yachtz Longboard Kingpin Replacement, Kingpin: passo 1, immagine 2 di 3 Land Yachtz Longboard Kingpin Replacement, Kingpin: passo 1, immagine 3 di 3
    • Use a 3/8" socket wrench, adjustable wrench, or skate tool to take off all 4 of the screws holding the truck to the board.
  2. Land Yachtz Longboard Kingpin Replacement: passo 2, immagine 1 di 2 Land Yachtz Longboard Kingpin Replacement: passo 2, immagine 2 di 2
    • Use a skate tool or a 1/2" socket wrench to remove the wheel nut and take the wheels off of the truck.
  3. Land Yachtz Longboard Kingpin Replacement: passo 3, immagine 1 di 3 Land Yachtz Longboard Kingpin Replacement: passo 3, immagine 2 di 3 Land Yachtz Longboard Kingpin Replacement: passo 3, immagine 3 di 3
    • Take off the first nut securing the axle of the truck to the kingpin.
    • Remove the axle of the truck from the truck fastener.
    • Remove the second nut securing the kingpin in place.
  4. Land Yachtz Longboard Kingpin Replacement: passo 4, immagine 1 di 2 Land Yachtz Longboard Kingpin Replacement: passo 4, immagine 2 di 2
    • Remove the faulty kingpin from the truck.
  5. Land Yachtz Longboard Kingpin Replacement: passo 5, immagine 1 di 1
    • If the kingpin is stuck in the truck, firmly hammer it to get it loose.
    • Be careful not to hit your hand with the hammer. If your finger joints are placed in an awkward position, even an accidental hit from the hammer can cause injury.
  6. Land Yachtz Longboard Kingpin Replacement: passo 6, immagine 1 di 2 Land Yachtz Longboard Kingpin Replacement: passo 6, immagine 2 di 2
    • Insert the new kingpin and hammer it in if needed.
    • Be careful of your fingers when hammering the kingpin back in. Injury can result from even a glancing hit.
  7. Land Yachtz Longboard Kingpin Replacement: passo 7, immagine 1 di 3 Land Yachtz Longboard Kingpin Replacement: passo 7, immagine 2 di 3 Land Yachtz Longboard Kingpin Replacement: passo 7, immagine 3 di 3
    • Put the nut that secures the kingpin back in place.
    • Put the axle back on the truck and kingpin.
    • Put the final nut back onto the kingpin to secure it to the axle.
  8. Land Yachtz Longboard Kingpin Replacement: passo 8, immagine 1 di 1
    • Tighten the nut on the kingpin using a 9/16" socket wrench or skate tool.
  9. Land Yachtz Longboard Kingpin Replacement: passo 9, immagine 1 di 2 Land Yachtz Longboard Kingpin Replacement: passo 9, immagine 2 di 2
    • Reattach the wheels to the truck using the 1/2" socket wrench or skate tool.
  10. Land Yachtz Longboard Kingpin Replacement: passo 10, immagine 1 di 3 Land Yachtz Longboard Kingpin Replacement: passo 10, immagine 2 di 3 Land Yachtz Longboard Kingpin Replacement: passo 10, immagine 3 di 3
    • Reattach the truck to the skateboard using Phillips #1 screwdriver and 3/8" socket wrench or skate tool to screw the nut back on the screw.
    • Be sure that the kingpin is facing the end of the board when putting the trucks back on.
Conclusione
Test out your longboard and make sure that you can tighten and loosen the trucks effectively. Take it for a ride and make sure that turning works as you expect it to. If the problem persists, double-check to make sure that everything is put on correctly and the nuts are all securely fastened.
Max Badal
Membro da: 01/26/23
181 Reputazione
1 Guida realizzata
UC Davis, Team 2-2, Morris Winter 2023 Membro di UC Davis, Team 2-2, Morris Winter 2023
UCD-MORRIS-W23S2G2
2 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 184
