LG VX7000 External LCD Display Replacement
Introduzione
Vai al passo 1Sat on your phone and cracked the outer screen? Then here is the guide on how to replace it.
NOTE: Replacing the outer screen requires replacing the entire outer casing.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Using a pair of tweezers, remove the rubber screw covers located at each corner of the main screen.
Turn the screwdriver counterclockwise to unscrew the screws located under the recently removed rubber plugs.
