Salta al contenuto principale
LG Refrigerator Control Board Replacement
Cosa ti serve
    1. LG Refrigerator Control Board Replacement, Unplug your refrigerator: passo 1, immagine 1 di 1
      • Unplug your refrigerator before you begin your repair.
      • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
      • Condenser fan motor
      • Compressor motor and thermal overload device
      • Water supply valve assembly
      Chiedi a FixBot
      Aggiungi Commento
    1. LG Refrigerator Control Board Replacement, Unfasten the control board cover: passo 2, immagine 1 di 1
      • Use a Phillips screwdriver to remove the screws securing the control board cover.
      Chiedi a FixBot
      Aggiungi Commento
    2. LG Refrigerator Control Board Replacement, Remove the control board cover: passo 3, immagine 1 di 3 LG Refrigerator Control Board Replacement, Remove the control board cover: passo 3, immagine 2 di 3 LG Refrigerator Control Board Replacement, Remove the control board cover: passo 3, immagine 3 di 3
      • Tilt the top edge of the cover toward you and lift it off.
      Chiedi a FixBot
      Aggiungi Commento
    1. LG Refrigerator Control Board Replacement, Disconnect the control board: passo 4, immagine 1 di 3 LG Refrigerator Control Board Replacement, Disconnect the control board: passo 4, immagine 2 di 3 LG Refrigerator Control Board Replacement, Disconnect the control board: passo 4, immagine 3 di 3
      • Note the position of each of the connectors, before disconnecting them. A photo is very valuable for keeping track, and taking several as you progress may be helpful.
      • Squeeze and pull the connectors to disconnect them from the control board.
      • Make sure to fully reconnect each connector when reassembling.
      Chiedi a FixBot
      Aggiungi Commento
    2. LG Refrigerator Control Board Replacement, Release the control board: passo 5, immagine 1 di 3 LG Refrigerator Control Board Replacement, Release the control board: passo 5, immagine 2 di 3 LG Refrigerator Control Board Replacement, Release the control board: passo 5, immagine 3 di 3
      • Use your thumb to pry up and release the top left retaining clip securing the control board.
      • With your other hand, pull the top left corner of the control board out to loosen it.
      Chiedi a FixBot
      Aggiungi Commento
    3. LG Refrigerator Control Board Replacement: passo 6, immagine 1 di 3 LG Refrigerator Control Board Replacement: passo 6, immagine 2 di 3 LG Refrigerator Control Board Replacement: passo 6, immagine 3 di 3
      • Repeat this process for each tab down the left edge of the control board as well as the top and bottom edges.
      Chiedi a FixBot
      Aggiungi Commento
    4. LG Refrigerator Control Board Replacement, Remove the control board: passo 7, immagine 1 di 1
      • Lift the control board out by its edges and remove it.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Altre 4 persone hanno completato questa guida.
Bill Gilbert
Membro da: 06/30/22
40.168 Reputazione
261 guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
49.827 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 11
Ultimi 7 giorni: 57
Ultimi 30 giorni: 258
Tutti i Tempi: 4,997
