LG Optimus L9 P769 VGA Front Facing Camera Replacement
Introduzione
Vai al passo 1This repair requires the user to disassemble the device completely, removing the screen to reach the front facing camera. The user should be cautious when removing ribbon cables to ensure that they are not torn or broken. The user should also take extreme care when removing the motherboard as it is very delicate and easily damaged.
Cosa ti serve
Start by placing the device face down and remove the back cove.
Remove the battery from the phone by lifting it using your finger or the prying tool
Using a spudger or small prying tool, pry off the latches that connects the digitizer to the chassis carefully.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Remove the primary or rear camera using a small opening tool to remove the adhesive and lift the camera up using a pair of tweezers.
Using the same small opening tool, remove the connector that is taped to the chassis of the phone.
Once the screen has been removed, use a prying tool to lift off the front facing camera.
