Salta al contenuto principale
LG G6 SIM Card Reader Replacement
MovilOne
MovilOne e 2 altri collaboratori
Ultimo aggiornamento il August 5, 2024
25 minuti
Molto difficile
Guida fornita dalla comunità
Dettagli Mancanti
Introduzione
Vai al passo 1
This guide requires specialized equipment and microsoldering knowledge.
    • Insert wisdom here.
Conclusione
MovilOne
Membro da: 06/17/14
2.480 Reputazione
11 Guide realizzate
3Commenti sulla guida
Nice Work. Instead of using the iron to solder it to the board, could you use a heat gun instead?
B Thomp - Replica
Yes, use leaded solder and small amount of no clean flux, maximum heat of 250 c, as described my Molex datasheets and part will self align
Greg Hamilton - Replica
We have repaired many of these LG G6 phones with damage to the sim card reader, it looks like it is a very common issue with this phone. The sim card tray gets stuck or jammed inside the reader, and when force is applied to pull the tray out, it ends up damaging the pins for the sim card or memory card reader. It is easily repaired though if you have the correct tools and skills!
smartfonefix - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 4,389
