Salta al contenuto principale
LG G6 Cameras Replacement
Cosa ti serve
  1. LG G6 Cameras Replacement, Rear Glass Panel: passo 1, immagine 1 di 3 LG G6 Cameras Replacement, Rear Glass Panel: passo 1, immagine 2 di 3 LG G6 Cameras Replacement, Rear Glass Panel: passo 1, immagine 3 di 3
    • In the following steps you'll be cutting through the adhesive that adheres the rear glass panel to the phone.
    • For reference, the backside of the panel is shown in the first photo. Note the clearance between the edge of the panel and the fragile ribbon cable beside the fingerprint sensor.
    • Be careful as you slice and pry to the left side of the fingerprint sensor, as seen from the outside of the phone in the third photo.
    • Inserting an opening tool more than 3 mm into the phone in this area can damage or tear the fingerprint sensor cable.
    In the UK, the battery will cost you around £12 from Amazon, which would seem makes this exercise worth while. Very nice guide, but it should come with a warning that you should only attempt this knowing the risk that you may completely destroy your phone. You are also very likely to remove any kind of water and dust damage protection in the process. Probably worth letting a professional do it if you do not feel too confident in your abilities…
    Lardy - Replica
  2. LG G6 Cameras Replacement: passo 2, immagine 1 di 1
    • Heating the backside of the G6 helps soften the adhesive securing the rear panel, making it easier to open.
    • Use a hairdryer, a heat gun, or prepare an iOpener and apply it to the lower edge of the G6 for about a minute to soften up the adhesive underneath the rear glass panel.
  3. LG G6 Cameras Replacement: passo 3, immagine 1 di 2 LG G6 Cameras Replacement: passo 3, immagine 2 di 2
    • Secure a suction cup to the rear panel, as close to the heated edge as possible.
  4. LG G6 Cameras Replacement: passo 4, immagine 1 di 3 LG G6 Cameras Replacement: passo 4, immagine 2 di 3 LG G6 Cameras Replacement: passo 4, immagine 3 di 3
    • To make this step easier, you can prop up the heated edge of the phone on something that is about 0.5 inches (13 mm) thick, like an eraser. This will angle the phone so that the opening tool is easier to insert.
    • If you don't have a small object for propping, you can (carefully) perform this step at the edge of a desk or table to achieve the same angle of entry.
    • Lift the rear panel's bottom edge with your suction cup, opening a slight gap between the panel and the frame.
    • This may require a significant amount of force. If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
    • Once you've created a gap, press the flat end of an opening tool into the gap.
    • The rear glass panel is fragile and can break if you use too much force or attempt to pry with metal tools.
  5. LG G6 Cameras Replacement: passo 5, immagine 1 di 3 LG G6 Cameras Replacement: passo 5, immagine 2 di 3 LG G6 Cameras Replacement: passo 5, immagine 3 di 3
    • Slide the opening tool back and forth across the bottom edge of the phone, cutting through the adhesive securing the rear glass panel.
    • Once the adhesive is cut and the gap is wide enough, insert an opening pick into the gap to keep the adhesive from re-bonding. Remove the opening tool.
  6. LG G6 Cameras Replacement: passo 6, immagine 1 di 3 LG G6 Cameras Replacement: passo 6, immagine 2 di 3 LG G6 Cameras Replacement: passo 6, immagine 3 di 3
    • As you proceed with separating the adhesive, you might need to re-apply heat to each edge before you can slice the adhesive securing it.
    • Additionally, you can use multiple opening picks for this process, leaving one in place on each side after you finish slicing to prevent the adhesive from re-adhering as it cools.
    • Slide the opening pick along the left edge of the phone to slice through the adhesive securing the rear panel.
  7. LG G6 Cameras Replacement: passo 7, immagine 1 di 3 LG G6 Cameras Replacement: passo 7, immagine 2 di 3 LG G6 Cameras Replacement: passo 7, immagine 3 di 3
    • Re-insert the opening pick into the bottom edge of the phone and slide it up the right edge of the phone, cutting through the adhesive holding it in place.
  8. LG G6 Cameras Replacement: passo 8, immagine 1 di 3 LG G6 Cameras Replacement: passo 8, immagine 2 di 3 LG G6 Cameras Replacement: passo 8, immagine 3 di 3
    • As seen in Step 1, the fingerprint reader cable runs to the left of the camera, fairly close to the edge of the phone. Be careful as you cut through the adhesive in the upper edges of the phone.
    • Carefully slide an opening pick across the top edge of the phone, separating the last of the adhesive securing the rear glass panel.
  9. LG G6 Cameras Replacement: passo 9, immagine 1 di 3 LG G6 Cameras Replacement: passo 9, immagine 2 di 3 LG G6 Cameras Replacement: passo 9, immagine 3 di 3
    • Once all the adhesive is cut, use an opening pick to pry up the rear glass panel.
    • Remove the panel.
  10. LG G6 Cameras Replacement: passo 10, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • If reusing the rear glass panel during reassembly:
    • Use tweezers to peel away any remaining adhesive from both the rear panel and the phone's chassis.
    • Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
    • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • Peel away the replacement adhesive's liner, align it with the back of the phone, and press it into place.
    • Remove any remaining liners, and replace the rear glass panel.
    • After installing the rear panel, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
    • You can also reinstall the rear panel without replacing the adhesive. Remove any large chunks of adhesive that might prevent the panel from sitting down flush. After installation, heat the panel and apply pressure to secure it. The phone won't be waterproof, but the residual adhesive is usually more than strong enough to hold.
  11. LG G6 Cameras Replacement, Battery Disconnect: passo 11, immagine 1 di 2 LG G6 Cameras Replacement, Battery Disconnect: passo 11, immagine 2 di 2
    • Remove the four Phillips screws holding down the lower antenna shield.
    • Bonus points: remove the illegal Warranty Void If Removed sticker.
    Suggestion… reword it… “relocate warranty cod if…” sticker…;)
    Thomas Keats - Replica
    funny mine does not have void sticker
    Doubs - Replica
  12. LG G6 Cameras Replacement: passo 12, immagine 1 di 3 LG G6 Cameras Replacement: passo 12, immagine 2 di 3 LG G6 Cameras Replacement: passo 12, immagine 3 di 3
    • Insert the point of a spudger into the small gap between the lower antenna shield and the metal frame of the phone.
    • Gently pry up the antenna shield and remove it from the phone.
  13. LG G6 Cameras Replacement: passo 13, immagine 1 di 1
    • Remove the seven Phillips screws holding down the upper antenna shield.
    Schraube auf 3 Uhr ist unter dem Kleber versteckt.
    Screw at 3 o'clock is hidden underneath the glue pad.
    Daniel - Replica
  14. LG G6 Cameras Replacement: passo 14, immagine 1 di 3 LG G6 Cameras Replacement: passo 14, immagine 2 di 3 LG G6 Cameras Replacement: passo 14, immagine 3 di 3
    • Insert the flat end of a spudger into the small gap between the upper antenna shield and the phone chassis and pry up, releasing the clips holding the shield in place.
    • Remove the upper antenna shield and wireless charging coil.
  15. LG G6 Cameras Replacement: passo 15, immagine 1 di 2 LG G6 Cameras Replacement: passo 15, immagine 2 di 2
    • Use a spudger to pry up the press connector at the end of the battery's ribbon cable, disconnecting the battery.
    The hardest thing for me was getting the battery connector reconnected. I didn't want to break/bend anything. Maybe you can add a close up picture of both ends of the connector.
    Joseph Mizzi - Replica
  16. LG G6 Cameras Replacement, Motherboard: passo 16, immagine 1 di 3 LG G6 Cameras Replacement, Motherboard: passo 16, immagine 2 di 3 LG G6 Cameras Replacement, Motherboard: passo 16, immagine 3 di 3
    • Insert a SIM removal tool or the SIM removal bit into the hole opposite the volume buttons and press to release the SIM/MicroSD card tray.
    • Remove the SIM/MicroSD tray.
    • Do not skip this step! The motherboard cannot be removed from the device without first removing the SIM/SD tray.
    Beware ….. I’ve had two G6 phones with a “stuck” top edge of of tray (in your photo) that broke off and stayed “stuck” inside the motherboard connector. And, I used the proper tool for pushing into the hole to push the tray out from the back. I was able to get it all re-installed by pushing the sim-card in first and then pushing the tray in around the sim-card.
    Kirk Harris - Replica
    lg g6 মাদারবোর্ড সমস্যা টাস কাজ করে না
    MD khalek Khan - Replica
  17. LG G6 Cameras Replacement: passo 17, immagine 1 di 2 LG G6 Cameras Replacement: passo 17, immagine 2 di 2
    • Use the flat end of the spudger to lift up the two press connectors on the bottom end of the motherboard above the USB-C port.
  18. LG G6 Cameras Replacement: passo 18, immagine 1 di 1
    • Remove the sticker connecting the motherboard to the vibration motor.
  19. LG G6 Cameras Replacement: passo 19, immagine 1 di 3 LG G6 Cameras Replacement: passo 19, immagine 2 di 3 LG G6 Cameras Replacement: passo 19, immagine 3 di 3
    • Grab the motherboard by the top end (the end with the cameras) and gently lift it up and out of the phone.
    The tiny black box touching your index finger was not free to come out with my motherboard. I disconnected the ribbon cable from it’s connection on the motherboard and then removed the motherboard.
  20. LG G6 Cameras Replacement, Cameras: passo 20, immagine 1 di 3 LG G6 Cameras Replacement, Cameras: passo 20, immagine 2 di 3 LG G6 Cameras Replacement, Cameras: passo 20, immagine 3 di 3
    • Remove the two rear-facing and front-facing cameras from the motherboard.
Conclusione
Altre 3 persone hanno completato questa guida.
David Pugliese
Membro da: 09/26/17
1.156 Reputazione
4 Guide realizzate
USF Tampa, Team S2-G6, Passmore Fall 2017 Membro di USF Tampa, Team S2-G6, Passmore Fall 2017
USFT-PASSMORE-F17S2G6
4 Membri
11 Guide realizzate
3 Commenti
What is the recommended tape mm to use?
Chris Leong - Replica
After replacing both rear camera. I now get a camera error Camera unavailable. Any suggestion?
HungDinh - Replica
Did you ever solve this issue? I was considering attempting this but was unsure if using 3rd party hardware would be incompatible.
joseph fraser -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 21
Tutti i Tempi: 8,273
