Salta al contenuto principale
LG G Vista Charging Dock Replacement
Key Baker
Key Baker e 4 altri collaboratori
Ultimo aggiornamento il May 7, 2024
7 - 10 minuti
Moderato
Introduzione
Vai al passo 1
This guide will teach you how to replace the charging dock in your LG G Vista. In this guide you will need tweezers, and a spudger.
Cosa ti serve
Strumenti
Mostra di più…
  1. LG G Vista Charging Dock Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure the device is powered off.
  2. LG G Vista Charging Dock Replacement: passo 2, immagine 1 di 1
    • Remove the back cover by gently prying open the case of the device from the charging port.
  3. LG G Vista Charging Dock Replacement: passo 3, immagine 1 di 1
    • Lift the battery out of its place by prying up from the small notch at the base of the battery.
  4. LG G Vista Charging Dock Replacement, Charging Dock: passo 4, immagine 1 di 1
    • Using a Phillips #000 screwdriver, remove the eleven 3.0 mm screws around the perimeter of the phone.
  5. LG G Vista Charging Dock Replacement: passo 5, immagine 1 di 1
    • Use a plastic spudger, or finger nail, to lift up the hard shell on the top of the phone.
  6. LG G Vista Charging Dock Replacement: passo 6, immagine 1 di 2 LG G Vista Charging Dock Replacement: passo 6, immagine 2 di 2
    • Use a Phillips #000 screwdriver to remove the five 3.0 mm screws.
    • Remove the bottom hard shell from the device.
  7. LG G Vista Charging Dock Replacement: passo 7, immagine 1 di 2 LG G Vista Charging Dock Replacement: passo 7, immagine 2 di 2
    • Using a Phillips #000 screwdriver, remove the two screws from the device.
  8. LG G Vista Charging Dock Replacement: passo 8, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Using a pair of tweezers, lift up the two antennas surrounding the battery.
  9. LG G Vista Charging Dock Replacement: passo 9, immagine 1 di 1
    • Disconnect the two connectors on the right side of the charging port.
  10. LG G Vista Charging Dock Replacement: passo 10, immagine 1 di 1
    • Lift up the charging port with the plastic opening tool.
    • Remove the charging port from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 686
