Salta al contenuto principale
LG CF360 Back Cover Replacement
Kathrine Muirhead
Kathrine Muirhead e 3 altri collaboratori
Ultimo aggiornamento il May 7, 2024
5 - 10 minuti
Moderato
Introduzione
Vai al passo 1
The back case of the phone holds the motherboard and back speaker. You need to disassemble the back to replace these items.
Cosa ti serve
Strumenti
Mostra di più…
  1. LG CF360 Back Cover Replacement, Battery: passo 1, immagine 1 di 2 LG CF360 Back Cover Replacement, Battery: passo 1, immagine 2 di 2
    • On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
  2. LG CF360 Back Cover Replacement: passo 2, immagine 1 di 1
    • Lift and remove the battery.
  3. LG CF360 Back Cover Replacement, Back Cover: passo 3, immagine 1 di 2 LG CF360 Back Cover Replacement, Back Cover: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Remove the two screw covers at the top of phone with tweezers.
  4. LG CF360 Back Cover Replacement: passo 4, immagine 1 di 1
    • Remove the six Phillips #000 (3mm) screws.
  5. LG CF360 Back Cover Replacement: passo 5, immagine 1 di 3 LG CF360 Back Cover Replacement: passo 5, immagine 2 di 3 LG CF360 Back Cover Replacement: passo 5, immagine 3 di 3
    • Use the plastic opening tool to pry the back cover off. Insert the tool between the back cover and red mid section and go around the entire phone.
    • The plastic side buttons fall out when you take the back cover off.
    • The back cover is connected to the speaker by red and black wires.
  6. LG CF360 Back Cover Replacement: passo 6, immagine 1 di 1
    • Use the tweezers to remove the red and black wires connecting the speaker to the green motherboard by pinching the sides of the plastic base near the motherboard.
    • Set the back cover with the speaker aside.
Conclusione
Cal Poly, Team 4-27, Amido Fall 2013 Membro di Cal Poly, Team 4-27, Amido Fall 2013
CPSU-AMIDO-F13S4G27
4 Membri
19 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 328
