Salta al contenuto principale
LERSTA Floor Lamp Screw Terminal Replacement
[deleted]
[deleted] e un altro collaboratore
Ultimo aggiornamento il August 31, 2020
8 - 10 minuti
Facile
Introduzione
Vai al passo 1
This guide is about substituting the screw terminal of floor lamp, providing that the lamp socket is bad when normally trying to test the socket for power with a $5 circuit tester that lights off.
If you notice your lamp’s cords and plug are intact, or your lamp’s lighting bulb is properly functioning, then your lamp’s lighting socket may need to be replaced.
  1. LERSTA Floor Lamp Screw Terminal Replacement, Screw Terminal: passo 1, immagine 1 di 2 LERSTA Floor Lamp Screw Terminal Replacement, Screw Terminal: passo 1, immagine 2 di 2
    • Unplug the lamp.
  2. LERSTA Floor Lamp Screw Terminal Replacement: passo 2, immagine 1 di 1
    • Rotate the bulb counterclockwise to remove the light bulb.
  3. LERSTA Floor Lamp Screw Terminal Replacement: passo 3, immagine 1 di 1
    • Rotate the lamp shade counterclockwise.
  4. LERSTA Floor Lamp Screw Terminal Replacement: passo 4, immagine 1 di 1
    • Take the three parts aside after dismantling the lamp shade.
  5. LERSTA Floor Lamp Screw Terminal Replacement: passo 5, immagine 1 di 1
    • Dismantle the lamp shaft by rotating it counterclockwise.
  6. LERSTA Floor Lamp Screw Terminal Replacement: passo 6, immagine 1 di 1
    • Use a Phillips screwdriver to remove the two 3 mm screws from the silver cover.
    • Pull down both the silver cover and the black screw terminal.
  7. LERSTA Floor Lamp Screw Terminal Replacement: passo 7, immagine 1 di 1
    • Separate the light bulb socket from the silver cover by pulling the silver metal hasp in right-downward direction towards the lamp shaft.
    • Exert force on the both left and right hand sides of the hasp and then pull the hasp downward.
  8. LERSTA Floor Lamp Screw Terminal Replacement: passo 8, immagine 1 di 1
    • Replace the old bulb socket with a newly-purchased one.
Conclusione
Replacing the screw terminal of the floor lamp is relatively easy, but be cautious to deal with the step of the substitution of the light socket.
[deleted]
Membro da: 05/09/20
157 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,155
