Koss Porta Pro Speaker Holder Replacement
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
Use screwdriver to start bending edges of clip.
Continue bending with pliers or cutters.
Push clip with screwdriver and pull with cutters from another side.
Press tenon using screwdriver to remove shield.
Remove hoop from hoop holder.
Place hoop in hoop holer.
Close hoop holder with shield.
Insert M2.5x8 screw into hole and tighten the nut.
Stick comfortZone label over the screw. Use double-sided foam tape if head of screw is too high.
Stick cushion. Use additional double-sided tape if cushion has bad holding.
Left and right sides are the same so you can use this guide for both.
Altre 2 persone hanno completato questa guida.
Un commento
Where can you even get speaker holder mounts? The left one for mine broke but I cannot find just the speaker mount holder replacement, but whole headbands (which probably make more sense). Ifixit does not sell the parts and I cannot find anywhere where the parts are sold.
