Salta al contenuto principale
KitchenAid KHM512ER Eject Button Spring Replacement
Yuriy Zaynulin
Yuriy Zaynulin e 4 altri collaboratori
Ultimo aggiornamento il May 9, 2016
10 - 20 minuti
Moderato
Introduzione
Vai al passo 1
Beater Eject Button doesn't work? Follow this guide to replace it.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. KitchenAid KHM512ER Eject Button Spring Replacement, Eject Button Spring: passo 1, immagine 1 di 2 KitchenAid KHM512ER Eject Button Spring Replacement, Eject Button Spring: passo 1, immagine 2 di 2
    • Insert the back of a plastic opening tool into one of the beater holes.
    • Apply force to pull the circular plastic part off.
    • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
  2. KitchenAid KHM512ER Eject Button Spring Replacement: passo 2, immagine 1 di 3 KitchenAid KHM512ER Eject Button Spring Replacement: passo 2, immagine 2 di 3 KitchenAid KHM512ER Eject Button Spring Replacement: passo 2, immagine 3 di 3
    • Use a plastic opening tool to remove the speed knob.
    • Use a plastic opening tool to remove the long plastic piece
    • Use a plastic opening tool to remove the speed switch.
  3. KitchenAid KHM512ER Eject Button Spring Replacement: passo 3, immagine 1 di 2 KitchenAid KHM512ER Eject Button Spring Replacement: passo 3, immagine 2 di 2
    • Use a Phillips 2 screwdriver to remove the two 20.0mm screws holding the bottom plastic piece on.
    • Your screwdriver may not be long or narrow enough to reach the screws in these holes. If that's the case, use another screwdriver.
    • Remove the bottom plastic piece using a plastic opening tool.
  4. KitchenAid KHM512ER Eject Button Spring Replacement: passo 4, immagine 1 di 3 KitchenAid KHM512ER Eject Button Spring Replacement: passo 4, immagine 2 di 3 KitchenAid KHM512ER Eject Button Spring Replacement: passo 4, immagine 3 di 3
    • Using a Phillips 2 screwdriver, remove the three 20.0mm screws holding the motor assembly in place.
    • Use your hands to remove the motor assembly.
    • Use your hands to hold the eject button from one side while using the other hand to remove the circuit board.
  5. KitchenAid KHM512ER Eject Button Spring Replacement: passo 5, immagine 1 di 2 KitchenAid KHM512ER Eject Button Spring Replacement: passo 5, immagine 2 di 2
    • Remove the eject button by pulling it from the inside of the mixer.
    • Hold the eject button firmly while pulling out the spring.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 2-3, Sullivan Spring 2016 Membro di USF Tampa, Team 2-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G3
3 Membri
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 31
Tutti i Tempi: 1,735
