Salta al contenuto principale
Kemove Snowfox 61 Key Switch Replacement
Chandara Young
Chandara Young e 2 altri collaboratori
Ultimo aggiornamento il May 7, 2024
2 - 3 ore
Facile
Guida Studente in Evidenza
Introduzione
Vai al passo 1
Use this guide for replacing faulty key switches on the KEMOVE Snowfox 61 mechanical keyboard.
A mechanical keyboard with a faulty switch causes multiple key inputs to be pressed or not respond. This occurs when grime build-up is left for too long in the keyboard, causing some keys to no longer function, requiring replacing the keys completely or cleaning the board.
No special skills are required.
Any Gateron switches will work, such as red, blue, green, etc.
  1. Kemove Snowfox 61 Key Switch Replacement, Key Switch: passo 1, immagine 1 di 3 Kemove Snowfox 61 Key Switch Replacement, Key Switch: passo 1, immagine 2 di 3 Kemove Snowfox 61 Key Switch Replacement, Key Switch: passo 1, immagine 3 di 3
    • Do not disassemble the keyboard if the keyboard is connected to a power source.
    • Unplug the power cable from the keyboard.
  2. Kemove Snowfox 61 Key Switch Replacement: passo 2, immagine 1 di 3 Kemove Snowfox 61 Key Switch Replacement: passo 2, immagine 2 di 3 Kemove Snowfox 61 Key Switch Replacement: passo 2, immagine 3 di 3
    • Do not pull the keycap other than straight up.
    • Position the keycap puller directly above the keycap.
    • Push the keycap puller down until the two handles are underneath the keycap.
    • Remove all keys.
    • It may be easier to pull by rotating the puller at a 45-degree angle.
  3. Kemove Snowfox 61 Key Switch Replacement: passo 3, immagine 1 di 3 Kemove Snowfox 61 Key Switch Replacement: passo 3, immagine 2 di 3 Kemove Snowfox 61 Key Switch Replacement: passo 3, immagine 3 di 3
    • Fill the plastic container with water.
    • Add 2-3 drops of dish soap.
    • Put the keycaps in.
    • Let the keycaps soak for about 20-30 minutes.
  4. Kemove Snowfox 61 Key Switch Replacement: passo 4, immagine 1 di 3 Kemove Snowfox 61 Key Switch Replacement: passo 4, immagine 2 di 3 Kemove Snowfox 61 Key Switch Replacement: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Microfiber Cleaning Cloths
    $3.99
    • Do not leave in sunlight or use a hairdryer because the heat might cause the plastic to warp or bend.
    • Take out the keycaps.
    • Ensure that the keycaps are separated and facing down.
    • Let the keycaps dry for 45 minutes.
    • If you cannot wait for 45 minutes, you may use a microfiber cloth and hand dry the keycaps. But be thorough in the cleaning process as there may be excess water inside the keycaps.
  5. Kemove Snowfox 61 Key Switch Replacement: passo 5, immagine 1 di 3 Kemove Snowfox 61 Key Switch Replacement: passo 5, immagine 2 di 3 Kemove Snowfox 61 Key Switch Replacement: passo 5, immagine 3 di 3
    • Do not pull the key switch other than straight up.
    • Place the key switch puller above the key switch.
    • Push the tongs inward on both the white top and bottom ends.
    • Pull the key switch out.
    • Remove all key switches.
  6. Kemove Snowfox 61 Key Switch Replacement: passo 6, immagine 1 di 3 Kemove Snowfox 61 Key Switch Replacement: passo 6, immagine 2 di 3 Kemove Snowfox 61 Key Switch Replacement: passo 6, immagine 3 di 3
    • Do not squeeze or clean roughly as you may leak liquid into the board's interior.
    • Use a wet/ alcohol wipe and gently clean the surface board.
    • Use any tweezers or cotton swabs to clean tight corners of the board.
  7. Kemove Snowfox 61 Key Switch Replacement: passo 7, immagine 1 di 3 Kemove Snowfox 61 Key Switch Replacement: passo 7, immagine 2 di 3 Kemove Snowfox 61 Key Switch Replacement: passo 7, immagine 3 di 3
    • Do not bend or hold by the golden pins.
    • Match the key switch with the keyholes.
    • Align the two golden pins with the two tiny holes located by the bottom.
    • Push down.
    • You will hear a loud clicking noise when the key switch has locked in place.
  8. Kemove Snowfox 61 Key Switch Replacement: passo 8, immagine 1 di 3 Kemove Snowfox 61 Key Switch Replacement: passo 8, immagine 2 di 3 Kemove Snowfox 61 Key Switch Replacement: passo 8, immagine 3 di 3
    • Match the keycaps with the key switches.
    • Align the keycaps facing down and push straight.
    • Place all keycaps in their respective positions.
Conclusione
Just like brand new!
Chandara Young
Membro da: 10/05/21
157 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 35
Tutti i Tempi: 1,008
