Salta al contenuto principale
John Frieda JFHA5R Reset and Test Buttons Replacement
Lindsey Farley
Lindsey Farley e 3 altri collaboratori
Ultimo aggiornamento il March 20, 2018
15 minuti
Moderato
Attrezzi Non Corretti
Introduzione
Vai al passo 1
The reset and test buttons can stop working over time. This replacement guide will show how to properly replace the reset and test buttons.
Cosa ti serve
Strumenti
Mostra di più…
  1. John Frieda JFHA5R Reset and Test Buttons Replacement, Reset and Test Buttons: passo 1, immagine 1 di 1
    • Make sure the Salon Shape brush is unplugged, and do not use metals once you have pried open the power plug.
    • Unscrew the two screws using a 3.0 mm bit triangle head on the back of the power plug.
  2. John Frieda JFHA5R Reset and Test Buttons Replacement: passo 2, immagine 1 di 1
    • Use the spudger along either side to open up the power plug.
    • As the power plug is opened, the caution sticker on top of the plug will rip.
  3. John Frieda JFHA5R Reset and Test Buttons Replacement: passo 3, immagine 1 di 1
    • Slide slightly up to remove the back cover of the power plug.
  4. John Frieda JFHA5R Reset and Test Buttons Replacement: passo 4, immagine 1 di 1
    • Remove the red reset button by pulling it to the right.
  5. John Frieda JFHA5R Reset and Test Buttons Replacement: passo 5, immagine 1 di 1
    • Pull slightly left then up to remove the yellow test button.
Conclusione
IUPUI, Team S5-G1, Baechle Fall 2017 Membro di IUPUI, Team S5-G1, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G1
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 539
