Salta al contenuto principale
JBL Pulse 3 Motherboard Replacement
Kaitlyn Greenfield
Kaitlyn Greenfield e 2 altri collaboratori
Ultimo aggiornamento il May 7, 2024
20 - 25 minuti
Moderato
Necessarie Più Immagini
Introduzione
Vai al passo 1
The motherboard for the JBL Pulse 3 is located inside the LED light display next to the battery.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. JBL Pulse 3 Motherboard Replacement, Speaker Grill: passo 1, immagine 1 di 1
    • Lay the JBL Pulse 3 on its side as shown in the picture.
    • Use a plastic opening tool to lift the top right corner of the speaker grill. A small amount of force is necessary to remove the grill.
  2. JBL Pulse 3 Motherboard Replacement: passo 2, immagine 1 di 1
    • Repeat step 1 for bottom right corner of speaker grill.
  3. JBL Pulse 3 Motherboard Replacement: passo 3, immagine 1 di 2 JBL Pulse 3 Motherboard Replacement: passo 3, immagine 2 di 2
    • After pulling the right side of the grill off, place thumb underneath grill as shown in the picture.
    • Lift and pull straight out to pull grill off the posts.
    • Repeat steps 1-3 for the left side of the speaker grill on the JBL Pulse 3. The speaker grill should now be completely removed from the JBL Pulse 3.
  4. JBL Pulse 3 Motherboard Replacement, Outside Casing: passo 5, immagine 1 di 2 JBL Pulse 3 Motherboard Replacement, Outside Casing: passo 5, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the six black 6mm screws on the inside of the top of the bottom section.
  5. JBL Pulse 3 Motherboard Replacement: passo 6, immagine 1 di 2 JBL Pulse 3 Motherboard Replacement: passo 6, immagine 2 di 2
    • Turn the JBL Pulse 3 right-side up and unscrew the top ring of the device. A small amount of force and/or a cotton cloth may be necessary to remove this piece.
  6. JBL Pulse 3 Motherboard Replacement: passo 7, immagine 1 di 2 JBL Pulse 3 Motherboard Replacement: passo 7, immagine 2 di 2
    • Remove the six 5mm screws on top of the JBL Pulse 3 with a Phillips #0 screwdriver.
  7. JBL Pulse 3 Motherboard Replacement: passo 8, immagine 1 di 1
    • Pull off the top disc of the JBL Pulse 3.
  8. JBL Pulse 3 Motherboard Replacement: passo 9, immagine 1 di 2 JBL Pulse 3 Motherboard Replacement: passo 9, immagine 2 di 2
    • Remove the five 7mm screws on the inside of the JBL Pulse 3 with a Phillips #1 screwdriver.
  9. JBL Pulse 3 Motherboard Replacement: passo 10, immagine 1 di 2 JBL Pulse 3 Motherboard Replacement: passo 10, immagine 2 di 2
    • Peel off black, taped-on electrical lead from the inside side of the JBL Pulse 3.
  10. JBL Pulse 3 Motherboard Replacement: passo 11, immagine 1 di 1
    • Pull the top section of the JBL Pulse 3 up. The outside casing to the JBL Pulse 3 should now be removed.
  11. JBL Pulse 3 Motherboard Replacement, LED Light Display: passo 12, immagine 1 di 3 JBL Pulse 3 Motherboard Replacement, LED Light Display: passo 12, immagine 2 di 3 JBL Pulse 3 Motherboard Replacement, LED Light Display: passo 12, immagine 3 di 3
    • Use a Phillips #2 screwdriver to remove the six 11 mm screws that circle the bottom of the LED light display.
    • Pull the LED light display off of the JBL Pulse 3 base.
  12. JBL Pulse 3 Motherboard Replacement: passo 13, immagine 1 di 2 JBL Pulse 3 Motherboard Replacement: passo 13, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use tweezers to pull the five connections off of the LED light display.
  13. JBL Pulse 3 Motherboard Replacement, Motherboard: passo 14, immagine 1 di 2 JBL Pulse 3 Motherboard Replacement, Motherboard: passo 14, immagine 2 di 2
    • Using a Phillips #0 screwdriver, remove the two black 8mm screws on the bottom of the LED light display.
  14. JBL Pulse 3 Motherboard Replacement: passo 15, immagine 1 di 3 JBL Pulse 3 Motherboard Replacement: passo 15, immagine 2 di 3 JBL Pulse 3 Motherboard Replacement: passo 15, immagine 3 di 3
    • Pull out the motherboard slightly from the LED light display as shown. Using tweezers, unplug the three connections attached to the motherboard.
  15. JBL Pulse 3 Motherboard Replacement: passo 16, immagine 1 di 1
    • Pull the rest of the motherboard out from the LED light display.
    • Using wire cutters, snip the black wire connecting to the base of the JBL Pulse 3 at the base of the motherboard. The motherboard should now be removed from the JBL Pulse 3.
Conclusione
Note: To replace the motherboard, you will need to re-solder the black wire to the motherboard.
Altre 2 persone hanno completato questa guida.
Un commento
tengo un pulse 3 que la placa entro en corto… me gustaria saber si alguien me puede ayudar con el diagrama esquematico o algun foto donde pueda conseguir
Wilson Flores - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 33
Tutti i Tempi: 3,800
