Salta al contenuto principale
Install macOS Printer Drivers
  1. Install macOS Printer Drivers, Install macOS Printer Drivers: passo 1, immagine 1 di 2 Install macOS Printer Drivers, Install macOS Printer Drivers: passo 1, immagine 2 di 2
    • Find the driver for your printer brand on the link below:
    • https://support.apple.com/kb/index?page=...
    • Download the driver for your printer, by clicking on the "Download" button.
    • If the message: "This connection is not private" appears, open the page with the private mode of your browser.
    Chiedi a FixBot
    Aggiungi Commento
  2. Install macOS Printer Drivers: passo 2, immagine 1 di 2 Install macOS Printer Drivers: passo 2, immagine 2 di 2
    • Open your .dmg file
    • Open your .pkg file
    • If this message appears: "This update requires macOS 12.0 or earlier." click Close and continue with the next step.
    • Otherwise, continue with step 7.
    Chiedi a FixBot
    Aggiungi Commento
  3. Install macOS Printer Drivers: passo 3, immagine 1 di 3 Install macOS Printer Drivers: passo 3, immagine 2 di 3 Install macOS Printer Drivers: passo 3, immagine 3 di 3
    • Move your .pkg file to your desktop
    • Open Terminal
    • Enter: cd Desktop/ then press the Enter key
    Chiedi a FixBot
    Aggiungi Commento
  4. Install macOS Printer Drivers: passo 4, immagine 1 di 3 Install macOS Printer Drivers: passo 4, immagine 2 di 3 Install macOS Printer Drivers: passo 4, immagine 3 di 3
    • Enter the following command: pkgutil --expand FileName.pkg FileName
    • Change FileName to the name of your file, in both places.
    • Then press the Enter key.
    • A folder with the file name appears on your desktop.
    • Open the folder.
    Chiedi a FixBot
    Aggiungi Commento
  5. Install macOS Printer Drivers: passo 5, immagine 1 di 2 Install macOS Printer Drivers: passo 5, immagine 2 di 2
    • Open the Distribution file with TextEdit
    • Then change the number after (system.compareVersions(system.version.ProductVersion, '12.0')" to that of your macOS version or later.
    • Save the file and close it.
    Chiedi a FixBot
    Aggiungi Commento
  6. Install macOS Printer Drivers: passo 6, immagine 1 di 2 Install macOS Printer Drivers: passo 6, immagine 2 di 2
    • Return to the Terminal
    • Enter the following command: pkgutil --flatten FileName FileName.pkg and press the Enter key.
    • Close theTerminal and open FileName.pkg on your desktop.
    Chiedi a FixBot
    Aggiungi Commento
  7. Install macOS Printer Drivers: passo 7, immagine 1 di 1
    • Congratulations, you can proceed with the installation by following the steps one by one.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Congratulations, you made it!
Altre 3 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
fr en
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
2Commenti sulla guida
Merci pour cet excellent tutoriel, j'ai récupéré le fonctionnement de mon ancienne imprimante HP sur mon Mac !
Bravo !!!
Cédric Trocellier - Rispondi Condividi
Bonjours ,j'ai un ordinateur imac et je veux installer une imprimante canon, je dois telecharger un logiciel pour ça et je n'y arrive pas; pouvez vous m'aider svp; merci
Moh Cho - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 9
Ultimi 7 giorni: 25
Ultimi 30 giorni: 114
Tutti i Tempi: 5,320
