Salta al contenuto principale
Install Windows 10 on the Pixel
Kevin Fessler
Kevin Fessler e 3 altri collaboratori
Ultimo aggiornamento il June 28, 2023
25 - 55 minuti
Moderato
Guida fornita dalla comunità
Introduzione
Vai al passo 1
This guide will assume you are familiar with installing Windows on previous devices. Not all features may work perfectly in this installation. You will *not* have to flash the BIOS to achieve a Windows installation, but you will have to flash it if you want all the devices to work properly.
Important Note: As of mid-2019, there is no viable method for getting the Pixel’s trackpad working in Windows 10. This is due to proprietary firmware used in the trackpad bundle, the code for which is not available from the manufacturer. If you’re okay using this with a USB mouse, or trying your luck with Bluetooth, carry on! As of mid-2023, there is an I2C driver currently undergoing testing for the Pixel's trackpad and touch screen. It will be available soon.
  1. Install Windows 10 on the Pixel, Get your Pixel ready: passo 1, immagine 1 di 1
    • Backup your data before we begin
    • You'll want to prepare a MBR bootable USB 8.1/10 drive using Rufus or the Window 10 installation tool
    • Have an external USB keyboard and mouse ready
  2. Install Windows 10 on the Pixel, Developer mode and USB Boot: passo 2, immagine 1 di 3 Install Windows 10 on the Pixel, Developer mode and USB Boot: passo 2, immagine 2 di 3 Install Windows 10 on the Pixel, Developer mode and USB Boot: passo 2, immagine 3 di 3
    • Enable developer mode and legacy USB boot
    • Boot into ChromeOS
    • You'll get to the developer mode on screen. Press "ctrl" + "L" to boot into the legacy SeaBIOS
    https://www.youtube.com/watch?v=UWXO61_v... instruções de como inicializar com o boot
    lucasanjos63 - Replica
  3. Install Windows 10 on the Pixel, Boot into Windows 10: passo 3, immagine 1 di 2 Install Windows 10 on the Pixel, Boot into Windows 10: passo 3, immagine 2 di 2
    • Plug in your USB keyboard
    • Select the flash drive containing your Windows 10 installation
    • Boot into Windows 10
  4. Install Windows 10 on the Pixel, Prepare your SSD: passo 4, immagine 1 di 2 Install Windows 10 on the Pixel, Prepare your SSD: passo 4, immagine 2 di 2
    • Use the advanced tools to open up an elevated command prompt
    • Run diskpart and clean the storage on your SSD boot drive
  5. Install Windows 10 on the Pixel, Install Windows 10: passo 5, immagine 1 di 3 Install Windows 10 on the Pixel, Install Windows 10: passo 5, immagine 2 di 3 Install Windows 10 on the Pixel, Install Windows 10: passo 5, immagine 3 di 3
    • Reboot into the Windows installer from your USB drive
    • Click Install Now to install Windows 10
    • Select your SSD as the default install location
  6. Install Windows 10 on the Pixel, Wait a bit...: passo 6, immagine 1 di 1
    • Let Windows 10 install
    • Whenever the computer reboots. Press "ctrl" + "L" to get back to the BIOS
  7. Install Windows 10 on the Pixel, Setup Windows: passo 7, immagine 1 di 3 Install Windows 10 on the Pixel, Setup Windows: passo 7, immagine 2 di 3 Install Windows 10 on the Pixel, Setup Windows: passo 7, immagine 3 di 3
    • Follow the on-screen guide to finish installing Windows
    • Wi-Fi and audio should work out of the box, but you'll still need your USB keyboard/mouse to continue with the setup
    • We'll install drivers shortly
    • Cortana will likely be really loud.
    • Plug in a pair of headphones or silence her by clicking the mute button on the bottom right of the screen.
    window installaition stoped from step 7 ,'cause i lose power of electric city.then the pc is not laungh
    the sports entertainment - Replica
  8. Install Windows 10 on the Pixel, Install drivers & Customize: passo 8, immagine 1 di 1
    • Install all of your Windows device drivers (keyboard, trackpad, touchscreen) from Coolstar's webpage
    • https://coolstar.org/chromebook/windows-...
    • Note that drivers may be buggy. You might have to reinstall ChromeOS by using recovery in order to flash/re-flash the BIOS.
    • This is risky business, so only flash it if your drivers don't work out of the box and you have the technical know-how to fix it.
Conclusione
Enjoy running Windows on your Pixel and have the satisfaction that not many have attempted this feat!
Altre 18 persone hanno completato questa guida.
Kevin Fessler
Membro da: 04/16/16
1.830 Reputazione
4 Guide realizzate
17Commenti sulla guida
Hello, have you successfully gotten the trackpad to work? Last time I heard Coolstar claimed that this wouldn't be possible.
therealpurplesound - Replica
Yup, the track-pad works (mostly) how it supposed to. I just can't post the driver since Mr. Chromebox noted that it's closed source; therefore I've decided to go solo with my work. It's definitely not impossible, just hard to figure out how to use the Intel I2C interface which drives the touchpad. I'd recommend starting your research on the official Intel datasheet for the specification and take a look at the Linux community drivers written in C for inspiration. You should check the Reddit page in case Coolstar or Mr. Chromebox has found a way to circumvent the legality issues or issued a fix of their own.
Kevin Fessler -
Hey did you end up doing this therealpurplesound? I want to do this as well but the trackpad, touchscreen, audio and other basic features that I haven't got a solid answer on stop me.
Josh Chichon -
Does it rotate when you do it?
Technopal V2.0 -
Hi, in a comment above you mention that the touchpad / trackpad mostly works as it's supposed to , but for reasons you cannot link it, can you elaborate on this? Is there a public solution as I am a bit confused and wish to gather more information before going forward.
I just wish to understand if the Pixel 2013 will work (keyboard, touchpad, touchscreen, etc) under Windows 10 as a normal functioning laptop.
Thank you.
Josh Chichon - Replica
The Pixel will function as a normal laptop. The addition of peripherals such as a USB mouse will greatly help aid your use of the laptop in Windows. The driver that I was able to create was (and still is) buggy. I have since sold my Pixel laptop a month ago and discontinued development. Mr. Chromebox, various others in the Reddit community recognize that by releasing a public driver without the consent of Intel might spell trouble. So no such driver will be released for the original Pixel system architecture.
Kevin Fessler -
Can you add in a video to ease our understanding? Thx in advance :)
adimas hanindika - Replica
No response from the author to my own comment, I'm assuming he doesn't check this any more.
The real question at the end of the day is what does work and what doesn't, have you been able to find any more information and / or guides related to this?
Josh Chichon -
@ adimas hanindika -> No video (I have since sold my laptop). However, you are welcome to make your own and link it in the iFixit description :)
I do check the posts that you guys leave, I'm just not active in responding to them since I don't contribute to iFixit as much as I used to. I made a post on the Chromebook Reddit page a few months ago listing what does and doesn't work. One of the things that doesn't work without the drivers are the trackpad and touchscreen. You'd need to learn I2C interfacing via the Intel iGPU and unfortunately that information isn't really public (I think?) This is one of the reasons why Coolstar hasn't been able to make it work.
Kevin Fessler -
I definitely miss working on the Pixel, but the thing just gets way too hot and the battery life is abysmal.
Kevin Fessler -
I'm here out of desperation. I really want to see the touchpad/touchscreen working on this thing before it is completely obsolete. I don't know how to write drivers at all, so is there anyway I could talk to you to see if you could maybe help me out with it?
My UN on reddit is “koreanoverlord", please just reach out to me cause you are the only person I have found to get it to work.
koreanoverlord - Replica
So you want to convert a ChromeOS device into a Windows device that is buggy as !&&*? Why would anyone do that? Why did you guys not just purchase a Windows laptop to begin with? The Pixel is less than a year old. It is not like you want to re purpose a years old laptop now.
jamalnasir_2000 - Replica
The pixlebook is aesthetically pleasing and may be very attractive for pixel phone users. The thing is, ChromeOS is still a sub par OS for a laptop with this feature set. Had Google released this laptop with a W10 option, im sure it would be much more popular. but its now relegated to stylish nerds who want a pixelbook with W10. nothing that is availible for the ChromeOS will ever fully utilize the power of the hardware specs it has. it might at well have an Armscor or Snapdragon chip in it. Having a properly functioning W10 on this notebook would drastically open up its usability. but its basically all locked behind a useless OS. If the product wasn’t so damned attractive, nobody would care. So the nerds have to figure it out so we can debug using W10 on this machine. at least until google wisens up and either make ChromeOS compatible with windows apps and totally refines the interface, or gives future pixelbooks a windows option.
iamthepwnaciousflu -
Hi! is this going to be dual OS? if not, how can you make a dual boot system?
David Amor - Replica
When at the legacy sea bios option i am able to see the boot option but i am unable to select it, when pressing the number i am met with booting from hard drive rather then my usb drive
teddy nguyen - Replica
Track pad the only thing Not to work?
Does
Touch screen
Backlite Keyboard
Hi Def Screen
Audio
All work ?
I could like with that.
Bobbie McGee - Replica
the installaition stops from step 7,'cause i lose power of electric city.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 154
Tutti i Tempi: 50,762
