Insignia NS-F12R6-SS Fan Blade Replacement
7 - 10 minuti
Facile
Introduzione
Vai al passo 1In order to access the back of the fan cage and the motor housing, the fan blades must be removed.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
Unplug your fan.
Remove the 20 mm bolt that fastens the fan ring located at the bottom of the fan cage with a Phillips #3 screwdriver.
Remove the 8 mm bolt fastening the fan blades to the rotor with a Phillip #3 screwdriver.
Quasi finito!
Conclusione
