Salta al contenuto principale
Infrared Remote Control Cleaning
Juan A. - Repair Cafe
Juan A. - Repair Cafe e un altro collaboratore
Ultimo aggiornamento il 21 nov 2022
30 minuti - 1 ora
Facile
Guida fornita dalla comunità
Introduzione
Vai al passo 1
"A remote control is like a sponge" that absorbs moisture and dirt because it is often used with dirty or sweaty hands and sufferers from drops and knocks that can damage the seal.
Over time the most used buttons fail or stop working, To repair the buttons, it is typically best to disassemble the remote and do a simple and proper cleaning that anyone can do by following this guide.
This method may also apply to some wireless phones that have similar keypads.
  1. Infrared Remote Control Cleaning, Functionality test: passo 1, immagine 1 di 3 Infrared Remote Control Cleaning, Functionality test: passo 1, immagine 2 di 3 Infrared Remote Control Cleaning, Functionality test: passo 1, immagine 3 di 3
    • Remote controls use an infrared LED in the front. Sometimes it can be seen behind some kind of "window", which is why users point the remote at a device for it to work. It can be tested using the corresponding device, but it is always convenient to know additional forms of testing:
    • Using a digital camera: the infrared can be visible using almost any digital camera. There is no need to be fancy--simply use your phone's camera for this. Point the remote at your camera and press some buttons. They should make the LED produce a bluish-purplish light only visible in the camera screen. Here are some examples.
    • Using an AM radio: put the remote near an AM radio between 520 and 1600 kHz. You should hear some kind of click, or interference noise with different intensities based on the frequency.
  2. Infrared Remote Control Cleaning, Disassembling the Remote: passo 2, immagine 1 di 3 Infrared Remote Control Cleaning, Disassembling the Remote: passo 2, immagine 2 di 3 Infrared Remote Control Cleaning, Disassembling the Remote: passo 2, immagine 3 di 3
    • To disassemble the remote, look for the screw to remove the cover in the battery compartment, as shown in the image.
    • Even after the screws are removed, the front and back covers containing the circuitry might not be easily separated. To separate them, use a plastic card such as a bank card, by inserting a corner in the central part of the case. It is best not to use anything metallic to avoid damaging the case.
    • Move through the joint with the card until one of the covers is decoupled. Then the joint can be opened until the covers are completely separated.
  3. Infrared Remote Control Cleaning, Lid and Rubber Keypad Cleaning: passo 3, immagine 1 di 3 Infrared Remote Control Cleaning, Lid and Rubber Keypad Cleaning: passo 3, immagine 2 di 3 Infrared Remote Control Cleaning, Lid and Rubber Keypad Cleaning: passo 3, immagine 3 di 3
    • The first photo shows how much dirt and debris accumulated under the cover and on top of the flexible, grey keypad.
    • Pull the flexible rubber from the circuit, and on the back check that the keys end in a black piece that might be graphite or something similar. Normally the most used keys are more stained, as can be seen in the photos.
    • Gently wash the outer casings and the rubber flexible keypad with neutral soap and a discarded toothbrush. DO NOT wash the circuit board! Dry them thoroughly.
  4. Infrared Remote Control Cleaning, Cleaning the Printed Circuit: passo 4, immagine 1 di 3 Infrared Remote Control Cleaning, Cleaning the Printed Circuit: passo 4, immagine 2 di 3 Infrared Remote Control Cleaning, Cleaning the Printed Circuit: passo 4, immagine 3 di 3
    • The black tracks of the circuitboard will accumulate grease and dirt, specifically on the black screen-printed tracks that form the opposing combs that come into contact with the black part of the keys when pressed.
    • The tracks of the circuit can be cleaned with a cotton swab dipped in alcohol (common in a medicine cabinet) or, if possible, with isopropyl alcohol. Be careful not to erase the letters that the manufacturer sometimes prints on the board. Never wash the circuit board with water.
    • Let it completely dry. Appreciate the result of the cleaning.
    Its completely OK to use soap and water as long you dry it before placing the batteries. I commonly use my shower on notebooks with something spill on it or from pet owners i.e. full of fur
    Claudio Nervi - Replica
  5. Infrared Remote Control Cleaning, Assembly and testing: passo 5, immagine 1 di 3 Infrared Remote Control Cleaning, Assembly and testing: passo 5, immagine 2 di 3 Infrared Remote Control Cleaning, Assembly and testing: passo 5, immagine 3 di 3
    • In the picture you can see how clean now is both the PCB and the switches.
    • To assembly you often have to put the PCB into he bottom half, carefully threading the battery contacts into the case rails (if any), then aligning the buttons over the PCB and finish with the top half, be mindful of the LED or window in front, buttons should align themselves.
    • Is time to test again(like we first did) and if any button fais repeat the cleaning both in the PCB and the button itself with a cotton an alcohol. To ease this process you can test without the top halve, just aligning the buttons, or putting the top half but not pushing all the way until makes click "click" (more easily said than done)
    • If continues not working after you clearly see it clean you should pay attention to the graphite, there are some products to paint over them if they were worn out. Now clean and easy to see check for any lift or broken tracks.
    • If all goes well put the screw back, put some new batteries and pat you on the back, congratulations you made it! If all didn't go well still pat you on the back, you tried, next time you will not need a guide.
Conclusione
Anyone can complete this cleaning task.
Altre 7 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
es en
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Preparati per le riparazioni future
Acquista tutti
2Commenti sulla guida
Aunque he quitado la tapa delantera y tres tornillos de la parte trasera y no hay ninguno más en el compartimento de las pilas, no veo la forma de separar las carcasas del mando del aire acondicionado Fujitsu. Se ha puesto amarillo con el tiempo y me gustaría aclararlo con una solución de peróxido de hidrógeno + luz intensa, como he hecho en otras ocasiones con otros aparatos.
Los mandos del aire acondicionado son ligeramente distintos de los de TV, porque no se ve ranura lateral. ¿Alguien sabría por dónde “atacar”?
Es de este tipo: https://www.fujitsu-general.com/global/r...
carolaclavo - Replica
Si el mando funciona no me arriesgaría a romperlo y haría la limpieza superficialmente, pero si lo quieres intentar prueba:
- saca del todo la tapa de las pilas, por si hay algún tornillo más.
- si hay tornillos escondidos debajo de alguna etiqueta, presiona por la zona a ver si hay debajo algún agujero.
- quizás esté sujeto con pestañas y puedas hacer palanca con algún utensilio de plástico pero puede que se rompan.
Nos cuentas el resultado y nos detallas tu método de limpieza, gracias.
Juan A. - Repair Cafe - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 54
Tutti i Tempi: 2,403
