Salta al contenuto principale
IdeaPad L340-15API Battery Replacement
Cosa ti serve
  1. IdeaPad L340-15API Battery Replacement, Optical Drive: passo 1, immagine 1 di 2 IdeaPad L340-15API Battery Replacement, Optical Drive: passo 1, immagine 2 di 2
    • Before beginning the repair, make sure that the device is fully powered off.
    • Turn the laptop over so the bottom cover is facing up.
    • The small screw hole near the center of the case, marked with a tiny DVD icon and an arrow, secures the optical drive.
    Chiedi a FixBot
    Aggiungi Commento
  2. IdeaPad L340-15API Battery Replacement: passo 2, immagine 1 di 2 IdeaPad L340-15API Battery Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the 7.5 mm screw securing the optical drive.
    • Place the screw down safely in a container/magnet strip where it will not get lost while you are working. These screws are very small and easily misplaced.
    Chiedi a FixBot
    Aggiungi Commento
  3. IdeaPad L340-15API Battery Replacement: passo 3, immagine 1 di 2 IdeaPad L340-15API Battery Replacement: passo 3, immagine 2 di 2
    • Place your thumb at the seam between the optical drive and the device.
    • Gently pull the component straight out from the device, taking care not to pull at an angle.
    Chiedi a FixBot
    Aggiungi Commento
  4. IdeaPad L340-15API Battery Replacement, Battery: passo 4, immagine 1 di 2 IdeaPad L340-15API Battery Replacement, Battery: passo 4, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the twelve 7.5 mm screws from the back cover.
    Chiedi a FixBot
    Aggiungi Commento
  5. IdeaPad L340-15API Battery Replacement: passo 5, immagine 1 di 3 IdeaPad L340-15API Battery Replacement: passo 5, immagine 2 di 3 IdeaPad L340-15API Battery Replacement: passo 5, immagine 3 di 3
    • Insert a plastic opening pick in the back left corner and wedge the panel open.
    • Slide the pick around the edge of the laptop to release the clips as you lift the panel.
    • If the opening pick isn’t working, use the iFixit opening tool to gain more leverage.
    • Remove the bottom cover.
    Chiedi a FixBot
    Aggiungi Commento
  6. IdeaPad L340-15API Battery Replacement: passo 6, immagine 1 di 2 IdeaPad L340-15API Battery Replacement: passo 6, immagine 2 di 2
    • Use the Phillips #1 screwdriver to remove the five 6.5 mm screws securing the battery.
    • Use a container/magnet strip to store the screws while working.
    Chiedi a FixBot
    Aggiungi Commento
  7. IdeaPad L340-15API Battery Replacement: passo 7, immagine 1 di 3 IdeaPad L340-15API Battery Replacement: passo 7, immagine 2 di 3 IdeaPad L340-15API Battery Replacement: passo 7, immagine 3 di 3
    • Use the wide end of a spudger to push the connector tab, sliding the battery connector out of its socket.
    • It may take a lot of force to disconnect the cable. Go slowly, and don't pull on the cables.
    Chiedi a FixBot
    Aggiungi Commento
  8. IdeaPad L340-15API Battery Replacement: passo 8, immagine 1 di 1
    • Remove the battery from the laptop.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
For optimal performance, calibrate your newly installed battery after completing this guide.
Ian
Membro da: 10/15/25
347 Reputazione
2 guide realizzate
UMass Dartmouth, Team 2-5, Bowman Fall 2025 Membro di UMass Dartmouth, Team 2-5, Bowman Fall 2025
UMASSD-BOWMAN-F25S2G5
4 Membri
4 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 14
Ultimi 30 giorni: 61
Tutti i Tempi: 387
