Salta al contenuto principale
IBM ThinkPad X41 Keyboard Replacement
Lisbeth Cisneros
Lisbeth Cisneros e 2 altri collaboratori
Ultimo aggiornamento il April 16, 2017
20 - 45 minuti
Moderato
Introduzione
Vai al passo 1
This guide will show you how to replace your entire keyboard for your IBM ThinkPad X41.
Cosa ti serve
Strumenti
  1. IBM ThinkPad X41 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 3 IBM ThinkPad X41 Keyboard Replacement, Keyboard: passo 1, immagine 2 di 3 IBM ThinkPad X41 Keyboard Replacement, Keyboard: passo 1, immagine 3 di 3
    • Slide outward to unlock and lift battery up to remove.
    • Remove battery before keyboard to avoid damage to battery.
  2. IBM ThinkPad X41 Keyboard Replacement: passo 2, immagine 1 di 1
    • With a Phillips PH000 to remove all six 6 mm screws identified for the keyboard as shown.
  3. IBM ThinkPad X41 Keyboard Replacement: passo 3, immagine 1 di 3 IBM ThinkPad X41 Keyboard Replacement: passo 3, immagine 2 di 3 IBM ThinkPad X41 Keyboard Replacement: passo 3, immagine 3 di 3
    • Flip the laptop over once more returning it to its upright position and open laptop .
  4. IBM ThinkPad X41 Keyboard Replacement: passo 4, immagine 1 di 2 IBM ThinkPad X41 Keyboard Replacement: passo 4, immagine 2 di 2
    • Using your left hand, place thumb on the upper part of the keyboard and place your other thumb on the bottom part of the keyboard.
    • Push firmly upward with both thumbs. This will detach keyboard from base.
    • Be cautious when lifting as there is an orange connection cable still attached to the bottom side.
  5. IBM ThinkPad X41 Keyboard Replacement: passo 5, immagine 1 di 2 IBM ThinkPad X41 Keyboard Replacement: passo 5, immagine 2 di 2
    • Detach the connection to the motherboard by first sliding it towards you, then pulling upward away from your body.
    • This step's directions are based on the angle shown .
  6. IBM ThinkPad X41 Keyboard Replacement: passo 6, immagine 1 di 1
    • Lift the entire keyboard off the laptop.
Conclusione
CSU Fullerton, Team 2-4, Bruce Fall 2016 Membro di CSU Fullerton, Team 2-4, Bruce Fall 2016
CSUF-BRUCE-F16S2G4
4 Membri
8 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 797
