Salta al contenuto principale
IBM ThinkPad X41 Battery Replacement
Magaly Espinoza
Magaly Espinoza e 2 altri collaboratori
Ultimo aggiornamento il September 4, 2018
30 secondi
Molto facile
Introduzione
Vai al passo 1
Individuals will be able to replace their laptop's battery following these quick and easy steps.
  1. IBM ThinkPad X41 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Turn laptop over, make sure lid side is faced down.
  2. IBM ThinkPad X41 Battery Replacement: passo 2, immagine 1 di 1
    • Locate battery release button lock on laptop, and press down.
  3. IBM ThinkPad X41 Battery Replacement: passo 3, immagine 1 di 1
    • Hold laptop battery release button and gently pull battery away from laptop.
Conclusione
CSU Fullerton, Team 2-4, Bruce Fall 2016 Membro di CSU Fullerton, Team 2-4, Bruce Fall 2016
CSUF-BRUCE-F16S2G4
4 Membri
8 Guide realizzate
2 Commenti
How can you open the battery case and replace the lithium ion cells?
Janie Godfrey - Replica
This could be possible, but it's the hard way.
Open the battery case will be difficult, and you well need to keep the BMS circuit board inside the battery pack then build a battery pack with new cells and reactivate the BMS again as some battery BMS have a security that cut the power output when the BMS has stopped to be powered. So after replacing the cells, the battery might not work as is as the BMS might cut the power output of the battery pack.
I don't know if this battery pack has this kind of security on it's BMS.
Brendan -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 23
Tutti i Tempi: 1,064
