Salta al contenuto principale
IBM ThinkPad T30 Hard Drive Replacement
Allie Knauer
Allie Knauer e 13 altri collaboratori
Ultimo aggiornamento il December 15, 2023
5 - 10 minuti
Facile
Guida In Evidenza
Studente al lavoro
Introduzione
Vai al passo 1
In this guide, you will learn how to remove and replace a hard drive for an IBM ThinkPad T30 laptop. The laptop comes with an IDE / PATA Hard disk drive that is either 20/40/60GB and is easy to remove only using a few tools
Cosa ti serve
Kit di riparazione
Questi kit contengono tutti i ricambi e gli strumenti necessari per completare questa guida.
Ricambi
Strumenti
Mostra di più…
  1. IBM ThinkPad T30 Hard Drive Replacement, Battery: passo 1, immagine 1 di 3 IBM ThinkPad T30 Hard Drive Replacement, Battery: passo 1, immagine 2 di 3 IBM ThinkPad T30 Hard Drive Replacement, Battery: passo 1, immagine 3 di 3
    • Before starting, make sure to have the Think pad turned off and the power supply is closed.
    • Flip the ThinkPad upside down with the bottom facing you.
    • Slide the latch to the right into the unlock position.
    • While holding the latch in the unlock position, lift the battery out with your other hand.
  2. IBM ThinkPad T30 Hard Drive Replacement, Hard Drive: passo 2, immagine 1 di 1
    • Flip to the back of the Thinkpad.
    • Remove the single 11 mm screw using the Phillips #0 screwdriver.
  3. IBM ThinkPad T30 Hard Drive Replacement: passo 3, immagine 1 di 3 IBM ThinkPad T30 Hard Drive Replacement: passo 3, immagine 2 di 3 IBM ThinkPad T30 Hard Drive Replacement: passo 3, immagine 3 di 3
    • Flip the Thinkpad on its side to get a better view of the hard drive.
    • Push on the lower edge of the hard drive cover to detach the hard drive from the Thinkpad.
    • Once you have detached the hard drive from the Thinkpad, slide the hard drive out of the device.
  4. IBM ThinkPad T30 Hard Drive Replacement: passo 4, immagine 1 di 2 IBM ThinkPad T30 Hard Drive Replacement: passo 4, immagine 2 di 2
    • Using the plastic tool, remove the black plastic cover from the main body of the hard drive.
    • Place the plastic tool at the ends of the plastic cover to detach it from the hard drive.
    • Once the black plastic has been detached, the plastic will then slide off the body of the hard drive.
  5. IBM ThinkPad T30 Hard Drive Replacement: passo 5, immagine 1 di 2 IBM ThinkPad T30 Hard Drive Replacement: passo 5, immagine 2 di 2
    • Remove the four 2.8 mm screws from the mounting bracket using a Phillips #0 screwdriver.
    • Pull the mounting bracket off of the hard drive.
    • It may be easier to remove the mounting bracket by rotating it off of the hard drive as if it is on a hinge.
Conclusione
To reassemble your device with a new hard drive, follow these instructions in reverse order with a new hard drive replacing the old one.
Altre 11 persone hanno completato questa guida.
Cal Poly, Team 3-20, Amido Fall 2012 Membro di Cal Poly, Team 3-20, Amido Fall 2012
CPSU-AMIDO-F12S3G20
3 Membri
16 Guide realizzate
1Commento della guida
good description and photos..thanks :]
David - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 40
Tutti i Tempi: 19,584
