Salta al contenuto principale
IBM ThinkPad 365 X/XD RAM Replacement
Olda1120
Olda1120 e un altro collaboratore
Ultimo aggiornamento il December 27, 2020
5 - 10 minuti
Facile
Guida fornita dalla comunità
Cosa ti serve
Strumenti
  1. IBM ThinkPad 365 X/XD RAM Replacement, Getting Inside the Thinkpad: passo 1, immagine 1 di 3 IBM ThinkPad 365 X/XD RAM Replacement, Getting Inside the Thinkpad: passo 1, immagine 2 di 3 IBM ThinkPad 365 X/XD RAM Replacement, Getting Inside the Thinkpad: passo 1, immagine 3 di 3
    • Using both latches on the left and right side of the Thinkpad, lift up the screen.
    • Again using both latches, push them back while pushing the keyboard up till it pops up, then lift the keyboard up. You may need to use a little force.
  2. IBM ThinkPad 365 X/XD RAM Replacement, Removing the Battery: passo 2, immagine 1 di 2 IBM ThinkPad 365 X/XD RAM Replacement, Removing the Battery: passo 2, immagine 2 di 2
    • Lift the battery using it's cloth pull tab and lift it out of the ThinkPad. Set it aside.
  3. IBM ThinkPad 365 X/XD RAM Replacement, Removing Screws/Lifting Cover: passo 3, immagine 1 di 2 IBM ThinkPad 365 X/XD RAM Replacement, Removing Screws/Lifting Cover: passo 3, immagine 2 di 2
    • Remove the following screws, there should be 3. Two of the screw spots may be slightly different on yours.
    • The cover has adhesive on it at these spots, pull it slowly till the adhesive releases. Then lift the cover up, you may need to hold it.
    • Keep track of the screws, the one that holds the drive to the board and cover is small, so don't loose it!
  4. IBM ThinkPad 365 X/XD RAM Replacement, Removing the RAM stick: passo 4, immagine 1 di 3 IBM ThinkPad 365 X/XD RAM Replacement, Removing the RAM stick: passo 4, immagine 2 di 3 IBM ThinkPad 365 X/XD RAM Replacement, Removing the RAM stick: passo 4, immagine 3 di 3
    • Using both hands, push the clips holding the RAM stick in outwards, till the RAM stick pops up.
    • Pull the stick out, and replace by pushing it in the same position you pulled it out, then down till the clips click.
    • Compatible with 144 pin 4x64-60ns EDO sticks. Some users have reported the ThinkPad can support up to 72 MB of ram using a 64 MB stick, but it has not worked for all users so there is no guarantee!
Conclusione
Olda1120
Membro da: 07/04/18
399 Reputazione
3 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 493
