Salta al contenuto principale
Huawei Honor 6x SIM Card Replacement
Kalynn Harris
Kalynn Harris e 2 altri collaboratori
Ultimo aggiornamento il September 4, 2021
2 minuti
Molto facile
Introduzione
Vai al passo 1
A SIM card connects the device to cellular services. Replacing a SIM card is necessary when changing your cellular provider or when your SIM card proves faulty.
  1. Huawei Honor 6x SIM Card Replacement, SIM Card: passo 1, immagine 1 di 1
    • Turn off the device.
  2. Huawei Honor 6x SIM Card Replacement: passo 2, immagine 1 di 2 Huawei Honor 6x SIM Card Replacement: passo 2, immagine 2 di 2
    • Insert the SIM Card Eject Tool into the SIM card tray hole.
    • Press the eject tool into the hole until the tray clicks open.
  3. Huawei Honor 6x SIM Card Replacement: passo 3, immagine 1 di 1
    • Remove the SIM tray from the device using two fingers.
    • When reinserting the SIM card, be sure it is properly aligned with the SIM tray.
  4. Huawei Honor 6x SIM Card Replacement: passo 4, immagine 1 di 1
    • Remove the SIM card from the compartment using two fingers.
Conclusione
Kalynn Harris
Membro da: 10/08/18
272 Reputazione
1 Guida realizzata
Cal Poly, Team S13-G5, White Fall 2018 Membro di Cal Poly, Team S13-G5, White Fall 2018
CPSU-WHITE-F18S13G5
4 Membri
14 Guide realizzate
Un commento
Internet connection
Pauline Heaney - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 34
Tutti i Tempi: 4,281
