Huawei Honor 6x Fingerprint Scanner Replacement
Introduzione
Vai al passo 1Use this guide to replace the fingerprint scanner assembly on your device. This requires the use of a heat gun to weaken adhesive, be safety cautious when using these tools.
Insert a plastic opening tool into the Micro USB charging port with the the angled side of the tool facing the screen.
Pry the screen off the back of the phone by pushing down on the opening tool.
Disconnect the fingerprint scanner cable attached to the motherboard using a spudger or your finger.
Altre 5 persone hanno completato questa guida.
