Huawei Honor 6x Battery Replacement
Introduzione
Vai al passo 1This guide will detail how to remove and replace the battery of the Huawei Honor 6x. The battery needs to be replaced when it loses charge faster than expected, or when it is broken.
Insert a plastic opening tool into the Micro USB charging port with the the angled side of the tool facing the screen.
Pry the screen off the back of the phone by pushing down on the opening tool.
Remove the motherboard cover from the device using a spudger or your fingers.
Always wear ESD Gloves before handling Motherboard.
anti-static or electrostatic discharge (ESD) gloves protect workers and the environment around them .
Remove the four connectors by placing the spudger between the motherboard and the connectors.
Press upwards against the connectors until they disconnect.
Attrezzo utilizzato in questo passaggio:Plastic Cards$2.99
Using the plastic card, remove the battery by lifting it from the casing.
Altre 16 persone hanno completato questa guida.
3 Commenti
Where do i get its original battery, its mostly fake batteries out there in online stores
@satyanarayan+debbarma
I used this battery I found on Amazon. It wasn’t the original, by Huawei, but it’s the exact same thing. Works perfectly fine.
Thanks very much
