Salta al contenuto principale
How to tighten the Razor A handlebar clamp
Jordyn
Jordyn e 3 altri collaboratori
Ultimo aggiornamento il August 4, 2023
1 - 2 minuti
Molto facile
Necessarie Immagini Migliori
Introduzione
Vai al passo 1
If your steering column suddenly collapses into itself, this guide is for you. This guide will show you how to tighten the T-tube column to prevent that from happening.
  1. How to tighten the Razor A handlebar clamp, How to tighten the Razor A handlebar clamp: passo 1, immagine 1 di 1
    • Locate the T-tube clamp. It is in the middle of the steering column.
  2. How to tighten the Razor A handlebar clamp: passo 2, immagine 1 di 2 How to tighten the Razor A handlebar clamp: passo 2, immagine 2 di 2
    • Open the clamp by pulling the lever away from the scooter.
  3. How to tighten the Razor A handlebar clamp: passo 3, immagine 1 di 2 How to tighten the Razor A handlebar clamp: passo 3, immagine 2 di 2
    • Locate the screw on the side of clamp.
    • Turn the screw on the side of the clamp by hand in a clockwise direction.
    • Attempt to close the clamp. If the lever is too tight to close, loosen the screw slightly and try again.
    • The T-tube should now be locked in place. If it continues to fall down, repeat the instructions in this guide.
Linea Traguardo
Jordyn
Membro da: 10/09/12
565 Reputazione
5 Guide realizzate
Cal Poly, Team 9-13, Amido Fall 2012 Membro di Cal Poly, Team 9-13, Amido Fall 2012
CPSU-AMIDO-F12S9G13
4 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 31
Tutti i Tempi: 3,956
