Salta al contenuto principale
How to rewire a Nostalgia Electrics PCM805
Carlton
Carlton e 5 altri collaboratori
Ultimo aggiornamento il 19 feb 2016
15 - 30 minuti
Difficile
Introduzione Migliore
Cosa ti serve
Ricambi
Strumenti
  • Wire Stripper
    Wire Stripper
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. How to rewire a Nostalgia Electrics PCM805, Nostalgia Electrics PCM805 Wiring Teardown: passo 1, immagine 1 di 2 How to rewire a Nostalgia Electrics PCM805, Nostalgia Electrics PCM805 Wiring Teardown: passo 1, immagine 2 di 2
    • Locate the tie strap holding the wires and cut with a pair of scissors.
    • Use care not to snip the wires.
  2. How to rewire a Nostalgia Electrics PCM805: passo 2, immagine 1 di 3 How to rewire a Nostalgia Electrics PCM805: passo 2, immagine 2 di 3 How to rewire a Nostalgia Electrics PCM805: passo 2, immagine 3 di 3
    • Make note of the wiring arrangement of each bundle before this step.
    • Using wire cutters, cut each wire as close to the wire connector as possible.
    • Cut the wires in both bundles.
    • To reassemble the cotton candy maker after cutting the wires, follow our rewiring guide.
  3. How to rewire a Nostalgia Electrics PCM805, How to rewire a Nostalgia Electrics PCM805: passo 3, immagine 1 di 2 How to rewire a Nostalgia Electrics PCM805, How to rewire a Nostalgia Electrics PCM805: passo 3, immagine 2 di 2
    • Using the wire stripper, remove 1/2 inch of the wire insulation at the end of each wire to expose the bare wire for re-connection.
  4. How to rewire a Nostalgia Electrics PCM805: passo 4, immagine 1 di 3 How to rewire a Nostalgia Electrics PCM805: passo 4, immagine 2 di 3 How to rewire a Nostalgia Electrics PCM805: passo 4, immagine 3 di 3
    • Twist the exposed ends of the wires so that they stay together.
    • Push the wire cap onto the exposed ends while holding the wires and twist in a clock-wise direction until it is tight.
    • Repeat this process for both bundles of wires.
    • Do not attempt to power on the device without the wire caps on or mix wires between the bundles.
Linea Traguardo
Carlton
Membro da: 01/13/15
672 Reputazione
5 Guide realizzate
USF Tampa, Team 3-5, Hickman Winter 2015 Membro di USF Tampa, Team 3-5, Hickman Winter 2015
USFT-HICKMAN-W15S3G5
5 Membri
8 Guide realizzate
1Commento della guida
DO NOT TRY THIS..it broke my machine TO NOT TRY THIS
Izzy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 770
