Salta al contenuto principale
How to remove and clean Arbor Rally Longboard bearings
Casey Barbello
Casey Barbello e 3 altri collaboratori
Ultimo aggiornamento il February 19, 2016
15 minuti
Facile
Introduzione
Vai al passo 1
If your Arbor Rally longboard has felt sluggish recently or you're not satisfied with it's performance, this guide will help you improve your ride.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. How to remove and clean Arbor Rally Longboard bearings, How to remove and clean Arbor Rally Longboard bearings: passo 1, immagine 1 di 2 How to remove and clean Arbor Rally Longboard bearings, How to remove and clean Arbor Rally Longboard bearings: passo 1, immagine 2 di 2
    • Use the half inch wrench to remove the nut on each wheel. Then remove each wheel.
    • Be careful not to lose the washers that sit between the nut and wheel, they are small and hard to find after you lose them.
  2. How to remove and clean Arbor Rally Longboard bearings: passo 2, immagine 1 di 3 How to remove and clean Arbor Rally Longboard bearings: passo 2, immagine 2 di 3 How to remove and clean Arbor Rally Longboard bearings: passo 2, immagine 3 di 3
    • Use needle nose pliers to remove the bearings from both sides of each wheel.
  3. How to remove and clean Arbor Rally Longboard bearings: passo 3, immagine 1 di 2 How to remove and clean Arbor Rally Longboard bearings: passo 3, immagine 2 di 2
    • Place the bearings in soapy water and let them soak for 5 minutes.
  4. How to remove and clean Arbor Rally Longboard bearings: passo 4, immagine 1 di 3 How to remove and clean Arbor Rally Longboard bearings: passo 4, immagine 2 di 3 How to remove and clean Arbor Rally Longboard bearings: passo 4, immagine 3 di 3
    • Wipe off the dirt from each bearing and dry them thoroughly with a paper towel.
  5. How to remove and clean Arbor Rally Longboard bearings: passo 5, immagine 1 di 2 How to remove and clean Arbor Rally Longboard bearings: passo 5, immagine 2 di 2
    • Apply a few drops of lubricant to the inner portion on both sides of each bearing.
    • Spin the bearings and wipe off any extra lubricant that has not settled in.
  6. How to remove and clean Arbor Rally Longboard bearings: passo 6, immagine 1 di 3 How to remove and clean Arbor Rally Longboard bearings: passo 6, immagine 2 di 3 How to remove and clean Arbor Rally Longboard bearings: passo 6, immagine 3 di 3
    • Push the bearing into the wheel by applying even pressure with your thumb.
  7. How to remove and clean Arbor Rally Longboard bearings: passo 7, immagine 1 di 3 How to remove and clean Arbor Rally Longboard bearings: passo 7, immagine 2 di 3 How to remove and clean Arbor Rally Longboard bearings: passo 7, immagine 3 di 3
    • Spin the wheel to make sure that the bearings are properly aligned and running smoothly.
  8. How to remove and clean Arbor Rally Longboard bearings: passo 8, immagine 1 di 3 How to remove and clean Arbor Rally Longboard bearings: passo 8, immagine 2 di 3 How to remove and clean Arbor Rally Longboard bearings: passo 8, immagine 3 di 3
    • Place the wheel on the axle followed by washer and then the nut.
    • Tighten the nut with your fingers as much as you can first and then use the wrench to finish the job.
    • Do not tighten the nut too much or else the wheel will not be able to spin. You should be able to slightly shake the wheel up and down along the axle.
Conclusione
Altre 4 persone hanno completato questa guida.
2 Commenti
Great guide! I was trying to figure out how to pop the bearings out - the needle nose pliers did a great job.
jewbot007 - Replica
It is usual practice to clean bearings with alcohol or a citrus cleaner; the latter is safer but more likely to leave residues. Since a citrus cleaning is water-based, you must quickly dry your bearings in order to prevent rust.
Mark Daniels - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 12,900
