How to refurbish and clean longboard bushings
Introduzione
Vai al passo 1In this guide we will learn how to refurbish and clean old longboard bushings that just don't work like they used to. Unresponsive bushings can be potentially dangerous when skating, as the bushings determine how the board turns. Through the use of boiling water, soap, and this guide, your longboard bushings will seem like they're brand new.
Cosa ti serve
Strumenti
Mostra di più…
Start by placing your board on its top so that you can access the trucks.
Use an adjustable wrench to remove the large nut that is screwed onto the end of the kingpin.
Once the trucks have been reassembled, step on the board and test the turning sensitivity.
If turning is hard or requires you to lean too much, loosen the nut.
If turning is too loose and not stable, tighten the nut.
You have successfully tuned your longboard with your "new" bushings and it's ready to ride!
Now you're all set to ride your longboard with your "new" bushings!
