Salta al contenuto principale
How to fix TC Electronic Level Pilot static noise
Alpha Dimension
Alpha Dimension e 4 altri collaboratori
Ultimo aggiornamento il 12 set 2024
2 - 5 minuti
Molto facile
Guida fornita dalla comunità
  1. How to fix TC Electronic Level Pilot static noise, How to fix TC Electronic Level Pilot static noise: passo 1, immagine 1 di 1
    • The bottom rubber base can be removed
  2. How to fix TC Electronic Level Pilot static noise: passo 2, immagine 1 di 1
    • Spray the small opening with electrical contact cleaner.
    • Only use electrical cleaning spray.
Conclusione
Altre 12 persone hanno completato questa guida.
6Commenti sulla guida
Not a good idea. Oil will &&^& it up dah.
stevenowlbassett - Replica
DeOxit (contact cleaner designed specifically for potentiometers) is what most people are recommending, not WD40 or dielectric grease..
Preferably DeOxit Gold, or at least not their (Hosa's) Fader Lube.
mystiphysician - Replica
Yes, use DeOxit or some similar contact cleaner
Eng Wei Chua - Replica
That knob became scratchy after some use. Cramolin contaclean helped, as always. Thanks for the teardown guide.
Daniel Leonov - Replica
Thanks Alpha Dimension for your disassembly guide.
If one needs to change it, it’s a Bourns potentiometer and its complete reference is PTD904-1020K-A103 (I’ve checked with measures on the potentiometer of my Level Pilot and with the PDF reference here : https://www.bourns.com/docs/product-data...)
Hervé HERRY - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 24
Tutti i Tempi: 5,997
