Salta al contenuto principale
How to effectively use AI prompting in Answers
Nick
Nick
Ultimo aggiornamento il 9 feb 2025
Nessuna stima
Moderato
In Lavorazione
Introduzione
Vai al passo 1
AUTHOR'S NOTE: While AI is largely condemned due to hallucination issues and hit-and-miss response quality, I am making this guide to educate someone using AI to get better response prompt results. I was hesitant to write this, but given that AI is likely here to stay, this educational material is likely a better long-term lesser evil.
This guide is intended for posters who intend to use AI to make their responses for Answers. Per the Community guidelines AI needs to be used with caution and verification of the response. This guide intends to bridge knowledge gaps that new users to tools like ChatGPT and Geminini may fall into due to issues like lack of iteration, bad initial details and other common quality pitfalls, which create poor quality responses. This guide is intended to help you properly prompt AI at a basic level, improving your answer quality and avoiding issues like the spam filter self-deleting your answers. AI must be used with caution, and the response must be verified independently before posing it to make sure the answer is accurate, safe, and well "written".
  1. How to effectively use AI prompting in Answers, IS THE QUESTION A GOOD CANDIATE?: passo 1, immagine 1 di 2 How to effectively use AI prompting in Answers, IS THE QUESTION A GOOD CANDIATE?: passo 1, immagine 2 di 2
    • Authors note for transparency: I wrote a sample question due to concerns about using a live question for this guide. You will see this in both responses. It is a way to show how to evaluate a live question for suitability with an AI tool like Google Gemini or ChatGPT.
    • Before attempting to use AI, make sure the question is a good candidate. In this example, the question here is almost certainly not a good starting point, and no amount of AI will fix this without the question poster adding additional key details. This question in it's initial form is a poor candidate. You should ask for more details.
    • When this question is fed into a AI tool (in this case, I used ChatGPT as Geminini requires a Google account for speed), the initial response is vague, unusable and not targeted due to the lack of information.
  2. How to effectively use AI prompting in Answers, Part 1: Bad candidate: passo 2, immagine 1 di 3 How to effectively use AI prompting in Answers, Part 1: Bad candidate: passo 2, immagine 2 di 3 How to effectively use AI prompting in Answers, Part 1: Bad candidate: passo 2, immagine 3 di 3
    • Due to photo limits, the followup questions will be spread over multiple parts.
    • How can we improve this? In Step 1, the sample question shown is so bad in its initial form, additional information is a must to properly answer it and cannot be used to get a good AI answer. As seen here, providing additional information improved the quality by a good margin but still lacks needed details.
  3. How to effectively use AI prompting in Answers, Part 2: Bad response: passo 3, immagine 1 di 3 How to effectively use AI prompting in Answers, Part 2: Bad response: passo 3, immagine 2 di 3 How to effectively use AI prompting in Answers, Part 2: Bad response: passo 3, immagine 3 di 3
    • Now that more details are available to better respond, we need to know key details such as he model year of the car, or model of the device. Once you know this, this very often helps find common causes. This is not a conclusive list, and basic research needs to be done before you trust the response.
    • Before moving forward, do not paste the information as-is into the answer as it was generated - ask the AI tool to summarize it Posting the snippets is far from helpful for someone who is not an expert.
  4. How to effectively use AI prompting in Answers, Part 3: Bad response - summarize the prompt: passo 4, immagine 1 di 3 How to effectively use AI prompting in Answers, Part 3: Bad response - summarize the prompt: passo 4, immagine 2 di 3 How to effectively use AI prompting in Answers, Part 3: Bad response - summarize the prompt: passo 4, immagine 3 di 3
    • BEFORE POSTING anything, ask the AI tool to summarize it for the skill level of the person asking - in this case, if the person has to go to a forum, they are likely not an automotive expert - they may know a thing or two, but that's probably it!
    • Ask your AI tool to summarize the information - do not post it as-is. This will not be helpful. This is an example of how to best accomplish this:
  5. How to effectively use AI prompting in Answers, IS THIS QUESTION A GOOD CANDIATE?: passo 5, immagine 1 di 1
    • When evaluating the base question, this is much more viable for AI to respond to. The reason this will take better then the "bad" example is because there is more meat to look into. It still will not be perfect out of the gate and may need iteration, but much less will be needed.
  6. How to effectively use AI prompting in Answers, Part 1: Good question: Iterating on it: passo 6, immagine 1 di 3 How to effectively use AI prompting in Answers, Part 1: Good question: Iterating on it: passo 6, immagine 2 di 3 How to effectively use AI prompting in Answers, Part 1: Good question: Iterating on it: passo 6, immagine 3 di 3
    • Some information is still missing, like the model year - you will still need to get this if it is not present. In this case, it is in the comments - 2013 Hyundai Elantra. You would add this to your prompt, which will help you (and the AI tool) find common faults known to occur on the vehicle (as well as common old Hyundai failures).
  7. How to effectively use AI prompting in Answers, Part 1: Good question: Iteration: passo 7, immagine 1 di 1
    • This is a continuation of Step 6 due to photo limits
  8. How to effectively use AI prompting in Answers, Part 2: Good question: Iteration: passo 8, immagine 1 di 1
    • Now that we have a good base response given the amount of usable details in the 2nd example, this response can likely be summarised without significant refinement, pending research to validate the response. For example: 2013 Hyundai Elantra common failures (personalize this to the question)
  9. How to effectively use AI prompting in Answers, Part 3: Good question: Iteration: passo 9, immagine 1 di 3 How to effectively use AI prompting in Answers, Part 3: Good question: Iteration: passo 9, immagine 2 di 3 How to effectively use AI prompting in Answers, Part 3: Good question: Iteration: passo 9, immagine 3 di 3
    • This is a continuation of Step 8
  10. How to effectively use AI prompting in Answers, Part 4: Good question: Iteration: passo 10, immagine 1 di 1
    • This is a continuation of Step 9
  11. How to effectively use AI prompting in Answers, Posting your answer - original: passo 11, immagine 1 di 2 How to effectively use AI prompting in Answers, Posting your answer - original: passo 11, immagine 2 di 2
    • BEFORE POSTING THE ANSWER, REMOVE DETAILS THAT MAY NOT BE HELPFUL OR CONFUSE THE OP. If they are needed, further rephrase it with a human touch once the initial "friendly" AI response is good. This is key, as even a good AI answer will often have lingering issues.
    • This initial answer is poor and unusable as-is. It needs refinement.
  12. How to effectively use AI prompting in Answers, Posting your answer - refined: passo 12, immagine 1 di 1
    • This example has been amended to show how to amend the final AI response properly.
Conclusione
Preparati per le riparazioni future
Acquista tutti
Nick
Membro da: 11/10/09
95.284 Reputazione
60 Guide realizzate
Master Techs Membro di Master Techs
Community
327 Membri
1.423 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 94
