Salta al contenuto principale
How to clean the Epson Stylus Photo 820 print rollers
Alex Lin
Alex Lin e 3 altri collaboratori
Ultimo aggiornamento il April 2, 2023
5 - 15 minuti
Facile
Introduzione
Vai al passo 1
Cleaning the inside of your printer with a Q-tip.
Cosa ti serve
Strumenti
  1. How to clean the Epson Stylus Photo 820 print rollers, How to clean the Epson Stylus Photo 820 print rollers: passo 1, immagine 1 di 2 How to clean the Epson Stylus Photo 820 print rollers, How to clean the Epson Stylus Photo 820 print rollers: passo 1, immagine 2 di 2
    • Safely unplug your printer.
    • Pull up on the tab to open the printer window.
    • Note: If you wish to clean more parts on the inside of your printer follow the guide to remove the top cover. This will give you access to more parts. After removing the top cover follow the next steps.
  2. How to clean the Epson Stylus Photo 820 print rollers: passo 2, immagine 1 di 2 How to clean the Epson Stylus Photo 820 print rollers: passo 2, immagine 2 di 2
    • Apply the Q-tip to the three black, cylindrical rollers shown in the picture. Clean them as much as you see fit.
    • If you notice a lot of dust on other parts of the printer you should clean those as well. For parts with a lot of surface area a damp cloth may be more useful.
    • Note: In the pictures, the top cover of the printer is removed.
  3. How to clean the Epson Stylus Photo 820 print rollers: passo 3, immagine 1 di 1
    • Close the printer door (or reattach the top cover if removed), and power on your printer.
Linea Traguardo
Alex Lin
Membro da: 04/10/11
99 Reputazione
3 Guide realizzate
Cal Poly, Team 20-68, Walters Spring 2011 Membro di Cal Poly, Team 20-68, Walters Spring 2011
CPSU-WALTERS-S11S20G68
4 Membri
12 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 19
Tutti i Tempi: 4,173
