Salta al contenuto principale
How to clean Sony CCD-TR81 viewfinder
Kevin
Kevin e 3 altri collaboratori
Ultimo aggiornamento il February 19, 2016
5 minuti
Facile
Introduzione
Vai al passo 1
Over time dust and condensate may start to gather on the lens that is between the displayed image in the viewfinder and the eyepiece. To return the image in the viewfinder, this quick guide gives a method to clean the lens if dust gathers, and if water condensate gathers on the inner eyepiece lens.
Cosa ti serve
Strumenti
  1. How to clean Sony CCD-TR81 viewfinder, Disassembling Sony CCD-TR81 Battery: passo 1, immagine 1 di 1
    • Lift viewfinder to access battery pack.
  2. How to clean Sony CCD-TR81 viewfinder: passo 2, immagine 1 di 2 How to clean Sony CCD-TR81 viewfinder: passo 2, immagine 2 di 2
    • Press the battery release button.
    • While pushing the battery button, slide the battery to the left.
  3. How to clean Sony CCD-TR81 viewfinder: passo 3, immagine 1 di 1
    • Pull the battery pack out of the video camera.
  4. How to clean Sony CCD-TR81 viewfinder, How to clean Sony CCD-TR81 viewfinder: passo 4, immagine 1 di 1
    • Pull the viewfinder eyepiece out and away from the main video camera until the black mark appears.
  5. How to clean Sony CCD-TR81 viewfinder: passo 5, immagine 1 di 1
    • Twist the eyepiece counterclockwise until it stops.
  6. How to clean Sony CCD-TR81 viewfinder: passo 6, immagine 1 di 1
    • Pull the eyepiece completely off away from the rest of the viewfinder.
  7. How to clean Sony CCD-TR81 viewfinder: passo 7, immagine 1 di 2 How to clean Sony CCD-TR81 viewfinder: passo 7, immagine 2 di 2
    • Using the Small Plastic Opening tool, pry the tab on the plastic lens away from the viewfinder.
  8. How to clean Sony CCD-TR81 viewfinder: passo 8, immagine 1 di 1
    • Use a cleaning cloth to wipe away residue from the viewfinder.
Conclusione
Kevin
Membro da: 01/24/11
252 Reputazione
3 Guide realizzate
Cal Poly, Team 11-25, Maness Winter 2011 Membro di Cal Poly, Team 11-25, Maness Winter 2011
CPSU-MANESS-W11S11G25
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 15
Tutti i Tempi: 3,992
