Salta al contenuto principale
How to align Razor A steering
Jordyn
Jordyn e 3 altri collaboratori
Ultimo aggiornamento il 3 ago 2023
3 - 5 minuti
Facile
Introduzione
Vai al passo 1
Sometimes a scooter will move in a different direction than the user directs it. This guide will demonstrate how to align the steering column with the front wheel, and so that the scooter moves properly in the right direction.
Cosa ti serve
Strumenti
  1. How to align Razor A steering, How to align Razor A steering: passo 1, immagine 1 di 3 How to align Razor A steering, How to align Razor A steering: passo 1, immagine 2 di 3 How to align Razor A steering, How to align Razor A steering: passo 1, immagine 3 di 3
    • Locate the collar clamp near the base of the steering column.
    • Insert a 3/16" Allen wrench into the screw in the collar clamp and loosen it.
    • The collar clamp will be free to move and may slide around the steering column. When reassembling, return it to its original position.
    at this part it would easily loosen for a few seconds then get hard again can you update this and mention that please if its normal
    Caleb Rigby (Awesomegamez) - Replica
    After loosening and re-aligning make sure to tighten it back up really tight so the problem will be avoided for a while. Eventually you will probably have to do this again after using the scooter a lot.
    Nolan Proulx - Replica
  2. How to align Razor A steering: passo 2, immagine 1 di 2 How to align Razor A steering: passo 2, immagine 2 di 2
    • Firmly grasp the steering column and turn the wheel by hand.
    • View the scooter along the steering column. Be sure the wheel is perpendicular to the handlebars.
    • The second picture above shows a correct alignment of the steering column from this view.
Linea Traguardo
Altre 17 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Jordyn
Membro da: 10/09/12
565 Reputazione
5 Guide realizzate
Cal Poly, Team 9-13, Amido Fall 2012 Membro di Cal Poly, Team 9-13, Amido Fall 2012
CPSU-AMIDO-F12S9G13
4 Membri
10 Guide realizzate
4Commenti sulla guida
This is so unhelpful.
Linh Tran - Replica
Great guide! Thanks so much helped me to fix my old scooter and save approx. $50
Max Kittens - Replica
Wow, fixed all the kids scooters on the block….THANK YOU!!!!!
Kathy Earhart - Replica
It worked for me for a little, but after a while the fix stopped working and i am back to where i started, and it is now as tight as it will go. They should really make the scooters better. The guide was really helpful, so thanks so much!
Alan Weinberg - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 65
Tutti i Tempi: 30,949
