How to Unclog a Shower Drain
Introduzione
Vai al passo 1In this guide, I will explain how to remove buildup in the shower drain.
Cosa ti serve
Ricambi
Mostra di più…
Begin by putting on a pair of disposable gloves to protect your hands from what is inside your drain and from the chemicals in drain opener.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Once the drain stopper is out of the way, use your fingers, tweezers, or almost any long thin object to pull out hair and larger items clogging the drain.
Dispose of anything you were able to remove from your drain.
If you cannot remove your drain stopper, skip ahead until step 7.
To reassemble your drain stopper, follow the steps you took in step one in reverse order.
Altre 2 persone hanno completato questa guida.
