Salta al contenuto principale
How to Safely Remove Stickers from a Hydro Flask
Karley Makar
Karley Makar e 2 altri collaboratori
Ultimo aggiornamento il December 18, 2024
30 - 40 minuti
Molto facile
Guida Studente in Evidenza
Introduzione
Vai al passo 1
Stickers have become a popular form of self-expression, and many are applied to reusable water bottles. However, we often outgrow the stickers we choose to place on our water bottles. This guide will share a safe and easy process for starting over in one's decorative process. You don't have to buy a new water bottle for a new look!
Before beginning, make sure to empty the water bottle of all its contents. The stickers you remove may not be reusable depending on how long they've been on the water bottle.
  1. How to Safely Remove Stickers from a Hydro Flask, How to Safely Remove Stickers from a Hydro Flask: passo 1, immagine 1 di 1
    • Soak the water bottle in warm water for 10 minutes.
  2. How to Safely Remove Stickers from a Hydro Flask: passo 2, immagine 1 di 2 How to Safely Remove Stickers from a Hydro Flask: passo 2, immagine 2 di 2
    • Dry the water bottle with a towel.
  3. How to Safely Remove Stickers from a Hydro Flask: passo 3, immagine 1 di 3 How to Safely Remove Stickers from a Hydro Flask: passo 3, immagine 2 di 3 How to Safely Remove Stickers from a Hydro Flask: passo 3, immagine 3 di 3
    • Turn the hair dryer on high heat.
    • Apply heat to each sticker for 30 seconds.
    • Slowly peel the sticker off while applying heat.
    • Caution: Be careful not to burn your fingers when peeling off the sticker.
  4. How to Safely Remove Stickers from a Hydro Flask: passo 4, immagine 1 di 3 How to Safely Remove Stickers from a Hydro Flask: passo 4, immagine 2 di 3 How to Safely Remove Stickers from a Hydro Flask: passo 4, immagine 3 di 3
    • Lather the water bottle in warm soapy water.
    • Scrub away at the residue with a sponge.
    • Dry down the water bottle with a towel.
  5. How to Safely Remove Stickers from a Hydro Flask: passo 5, immagine 1 di 3 How to Safely Remove Stickers from a Hydro Flask: passo 5, immagine 2 di 3 How to Safely Remove Stickers from a Hydro Flask: passo 5, immagine 3 di 3
    • Pour the isopropyl alcohol onto a cotton pad so that it is fully soaked.
    • Using pressure, rub the residue off of the water bottle with the cotton pad.
  6. How to Safely Remove Stickers from a Hydro Flask: passo 6, immagine 1 di 3 How to Safely Remove Stickers from a Hydro Flask: passo 6, immagine 2 di 3 How to Safely Remove Stickers from a Hydro Flask: passo 6, immagine 3 di 3
    • Scrape off the residue with a card. Scrape up to down.
    • Scrape from right to left.
  7. How to Safely Remove Stickers from a Hydro Flask: passo 7, immagine 1 di 3 How to Safely Remove Stickers from a Hydro Flask: passo 7, immagine 2 di 3 How to Safely Remove Stickers from a Hydro Flask: passo 7, immagine 3 di 3
    • Coat a cotton swab in the isopropyl alcohol.
    • With pressure, rub off the residue with the cotton swab.
    • For any difficult residue follow this step.
  8. How to Safely Remove Stickers from a Hydro Flask: passo 8, immagine 1 di 2 How to Safely Remove Stickers from a Hydro Flask: passo 8, immagine 2 di 2
    • Enjoy your new water bottle!
Linea Traguardo
Karley Makar
Membro da: 11/05/24
157 Reputazione
1 Guida realizzata
UC Davis, Team 4-5, Vidal-Chiesa Fall 2024 Membro di UC Davis, Team 4-5, Vidal-Chiesa Fall 2024
UCD-VIDAL-CHIESA-F24S4G5
2 Membri
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 106
