Salta al contenuto principale
How to Resurface a Fishing Lure
Zach Solka
Zach Solka e 4 altri collaboratori
Ultimo aggiornamento il July 26, 2023
30 minuti
Facile
Introduzione
Vai al passo 1
Fishing lures can be scratched or damaged in many ways as a resuIt of bouncing off rocks, becoming snagged, or worn from use. Scratches prevent metal lures from shining and attracting fish. In addition, wooden lures may absorb water which decreases their buoyancy. To initiate this repair you will need gloves, sandpaper, a can of liquid indoor/outdoor polyurethane, and possibly a pair of pliers. This project should be performed in a well ventilated area because of the polyurethane and the sanding required.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. How to Resurface a Fishing Lure, How to Resurface a Fishing Lure: passo 1, immagine 1 di 1
    • Evaluate the material your lures are made from. This will affect your process slightly.
  2. How to Resurface a Fishing Lure: passo 2, immagine 1 di 2 How to Resurface a Fishing Lure: passo 2, immagine 2 di 2
    • Remove the treble hooks and keyrings from the lure body.
    • The hooks are very sharp!
  3. How to Resurface a Fishing Lure: passo 3, immagine 1 di 2 How to Resurface a Fishing Lure: passo 3, immagine 2 di 2
    • Sand your lures. They can either be fully sanded or just scuffed on the surface. This helps the polyurethane bond to the surface.
    • Lures can be repainted with acrylic paints but that is out of the scope of this tutorial.
  4. How to Resurface a Fishing Lure: passo 4, immagine 1 di 2 How to Resurface a Fishing Lure: passo 4, immagine 2 di 2
    • Wipe the freshly sanded lures with a wet cloth. Allow it to fully dry.
  5. How to Resurface a Fishing Lure: passo 5, immagine 1 di 2 How to Resurface a Fishing Lure: passo 5, immagine 2 di 2
    • Tie a string to the lures and dip the lures fully into the polyurethane.
    • Do this step in a large and well ventilated space. Fumes from your polyurethane should not be inhaled.
  6. How to Resurface a Fishing Lure: passo 6, immagine 1 di 1
    • Hang your lures up to dry for at least 24 hours.
Conclusione
All that is necessary after the lure's new surface has cured is to reattach the keyring and treble hooks.
Zach Solka
Membro da: 03/30/16
149 Reputazione
1 Guida realizzata
2 Commenti
Looking for your first rod so you can take part in the great sport of fishing? Have you looked through some catalogs or browsed in sporting goods store and are already confused? All these new words to learn. Spinning fishing rods? Bait-casting '''fishing rods'''? Spin casting fishing rods? What do all these things mean?
mahbub_rahman - Replica
Very interesting post. Every step explains with the images are really helpful for the beginners. I love fishing in Puerto Vallarta and your post helps me a lot to resurface my fishing lure. Thanks a million and please keep up the effective work.
Marlas PV Landing - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 908
