Salta al contenuto principale
How to Restore Grip on Athletic Shoes
Aaron Downey
Aaron Downey e un altro collaboratore
Ultimo aggiornamento il November 13, 2024
30 minuti
Facile
Introduzione
Vai al passo 1
In this guide you will learn how to effectively restore the grip to the bottoms of athletic shoes. The seven step process will require the use of five household items.
  1. How to Restore Grip on Athletic Shoes, How to Restore Grip on Athletic Shoes: passo 1, immagine 1 di 1
    • Rinse shoe bottom under neutral temperature water to avoid cracks.
  2. How to Restore Grip on Athletic Shoes: passo 2, immagine 1 di 1
    • Make a mixture of dish soap and water in a small bowl.
  3. How to Restore Grip on Athletic Shoes: passo 3, immagine 1 di 2 How to Restore Grip on Athletic Shoes: passo 3, immagine 2 di 2
    • Use a soft bristle brush with the soap and water mixture to scrub dirt from bottom of shoe.
  4. How to Restore Grip on Athletic Shoes: passo 4, immagine 1 di 2 How to Restore Grip on Athletic Shoes: passo 4, immagine 2 di 2
    • Rinse soap from bottom of shoe and dry thoroughly with clean cloth.
  5. How to Restore Grip on Athletic Shoes: passo 5, immagine 1 di 1
    • Once the shoe is completely dry apply a thin coating of Vaseline.
  6. How to Restore Grip on Athletic Shoes: passo 6, immagine 1 di 1
    • Allow time for the Vaseline to completely dry.
  7. How to Restore Grip on Athletic Shoes: passo 7, immagine 1 di 1
    • Enjoy your athletic shoes with refurbished grip!
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
Seriously? Vaseline? Isn’t that one of the most slippery substances made?
Alyson Vega - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 52
Ultimi 30 Giorni: 190
Tutti i Tempi: 37,401
