Salta al contenuto principale
How to Replace the Cork in a Trombone Water Key
Esther Unti
Esther Unti e 4 altri collaboratori
Ultimo aggiornamento il 7 mag 2024
10 - 15 minuti
Facile
Introduzione
Vai al passo 1
A leaky water key can make playing difficult and a horn sound strange. Instrument repair professionals can fix leaky water keys, but often times all a water key needs is a new cork—an easy fix you can do at home. Water key corks are inexpensive and available at most music stores and online, but a wine cork cut to the right size will work in a pinch.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. How to Replace the Cork in a Trombone Water Key, Water Key Cork: passo 1, immagine 1 di 2 How to Replace the Cork in a Trombone Water Key, Water Key Cork: passo 1, immagine 2 di 2
    • Obtain a replacement water key cork.
    • If you’re in a rush and don’t have a replacement cork, you can make a temporary one out of a wine bottle cork.
  2. How to Replace the Cork in a Trombone Water Key: passo 2, immagine 1 di 3 How to Replace the Cork in a Trombone Water Key: passo 2, immagine 2 di 3 How to Replace the Cork in a Trombone Water Key: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Remove the old cork.
    • Insert a sharp tool, such as one tine of a pair of tweezers or needle-nose forceps, between the cork and the metal edge.
    • Pry up the cork using the metal edge for leverage.
    • Repeat this at several points around the cork until the cork comes free.
  3. How to Replace the Cork in a Trombone Water Key: passo 3, immagine 1 di 1
    • If you have a replacement cork, skip to Step 10.
    • If you’re using a wine bottle cork to make a replacement cork, place the cork on its side and measure 3 mm from the cork edge. Mark this point.
  4. How to Replace the Cork in a Trombone Water Key: passo 4, immagine 1 di 2 How to Replace the Cork in a Trombone Water Key: passo 4, immagine 2 di 2
    • Using a serrated knife (such as a steak knife), cut the cork horizontally along your mark.
    • Cutting corks can be tricky. Make sure to keep fingers out of your knife's way.
  5. How to Replace the Cork in a Trombone Water Key: passo 5, immagine 1 di 1
    • Using a ruler, measure the diameter of the water key slot you removed the cork from in Step 2.
    • Measure from inside edge to inside edge.
  6. How to Replace the Cork in a Trombone Water Key: passo 6, immagine 1 di 1
    • Place the 3mm slice you cut from the wine cork flat on a surface.
    • Mark a point in the center.
  7. How to Replace the Cork in a Trombone Water Key: passo 7, immagine 1 di 2 How to Replace the Cork in a Trombone Water Key: passo 7, immagine 2 di 2
    • Using a ruler, measure half the diameter from Step 5 above and below the center mark.
  8. How to Replace the Cork in a Trombone Water Key: passo 8, immagine 1 di 2 How to Replace the Cork in a Trombone Water Key: passo 8, immagine 2 di 2
    • Rotate the ruler 90 degrees and repeat Step 7.
    • Your cork slice should now have four marks equidistant from the center mark.
    • Draw a circle connecting the four marks around the center.
  9. How to Replace the Cork in a Trombone Water Key: passo 9, immagine 1 di 3 How to Replace the Cork in a Trombone Water Key: passo 9, immagine 2 di 3 How to Replace the Cork in a Trombone Water Key: passo 9, immagine 3 di 3
    • Using your knife, cut out this circle.
    • It helps to slice edges off at angles, one at a time.
    • This might take a few tries, so if you end up with a non-round circle cut out, repeat Steps 3-9 with the remaining wine cork.
  10. How to Replace the Cork in a Trombone Water Key: passo 10, immagine 1 di 1
    • Dry fit the new cork in the water key slot to make sure it is the right size.
    • If your cork is too big, you'll need to cut it a little smaller.
    • If your cork is a little uneven, don't worry. Its job is to seal the water hole, which is much smaller than the cork itself.
  11. How to Replace the Cork in a Trombone Water Key: passo 11, immagine 1 di 2 How to Replace the Cork in a Trombone Water Key: passo 11, immagine 2 di 2
    • With a hot glue gun, put a drop of glue in the water key slot and place the new cork on top.
    • Press firmly on the cork for a few seconds.
Conclusione
If your water key still leaks after replacing the cork, it may need to be bent back into place or may need a new spring. See an instrument repair professional or another online guide for help with this.
Altre 6 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Esther Unti
Membro da: 02/24/15
266 Reputazione
1 Guida realizzata
Cal Poly, Team 23-3, Green Winter 2015 Membro di Cal Poly, Team 23-3, Green Winter 2015
CPSU-GREEN-W15S23G3
6 Membri
13 Guide realizzate
1Commento della guida
Let me suggest that there is an easier way to a permanent solution for leaky corks - remove the water automatically by installing a JoyKey. No more leaking corks, no moving parts, no sptings or having to manually deal with water.
For more information:
www.thejoykey.com and http://thejoykey.com/wp-content/uploads/...
andrew - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 31
Tutti i Tempi: 13,692
