Salta al contenuto principale
How to Replace a Three-Prong Plug on a Power Strip
Arahey Garay
Arahey Garay e 2 altri collaboratori
Ultimo aggiornamento il March 20, 2023
55 minuti - 1 ora
Moderato
Introduzione
Vai al passo 1
With this guide you will learn how to restore a power strip by replacing its plug. For this guide we'll be specifically using ‘Construction Material Group’s Temporary Power Tap Model Number 6m15-6’ power strip. This plug in particular is missing the grounding pin which is used to prevent electrocution. Besides that, the ‘neutral’ and ‘hot’ pins are bent. All of these factors could create a recipe for disaster. With this guide we plan to help you replace the original prong with a new one making your power plug safer to use.
Remember to disconnect the power strip from the electrical source before starting any restoration. Also, it is recommended to work in a non-metal surface.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. How to Replace a Three-Prong Plug on a Power Strip, Three-Pole Plug: passo 1, immagine 1 di 1
    • Unplug the power strip and place it on a flat, non-metal surface.
  2. How to Replace a Three-Prong Plug on a Power Strip: passo 2, immagine 1 di 2 How to Replace a Three-Prong Plug on a Power Strip: passo 2, immagine 2 di 2
    • Cut near the base of the original plug, all the way through. Dispose of the old plug.
  3. How to Replace a Three-Prong Plug on a Power Strip: passo 3, immagine 1 di 1
    • Before attempting to work with the wires, insert the cord into a piece of heat shrink tubing. This will help to safely seal the wires later.
  4. How to Replace a Three-Prong Plug on a Power Strip: passo 4, immagine 1 di 2 How to Replace a Three-Prong Plug on a Power Strip: passo 4, immagine 2 di 2
    • Examine the 3 wires inside. You should see green, white, and black. Snip off any stray wires over a trash can.
  5. How to Replace a Three-Prong Plug on a Power Strip: passo 5, immagine 1 di 1
    • Strip back about 1/2 inch of the Wire with the wire strippers.
    • Braid the wires by gently twisting each strand so they stay with their same color wires.
  6. How to Replace a Three-Prong Plug on a Power Strip: passo 6, immagine 1 di 1
    • Unscrew the hinge on the new plug, set the screw somewhere safe for later.
  7. How to Replace a Three-Prong Plug on a Power Strip: passo 7, immagine 1 di 1
    • Make sure you have 3 different colored screws. Gold or dark colored, green and silver or light colored.
  8. How to Replace a Three-Prong Plug on a Power Strip: passo 8, immagine 1 di 3 How to Replace a Three-Prong Plug on a Power Strip: passo 8, immagine 2 di 3 How to Replace a Three-Prong Plug on a Power Strip: passo 8, immagine 3 di 3
    • Pair the black wire to the gold or dark colored screw. Once twisted around the screw clockwise, tighten it.
    • Pair the green wire to the green colored screw. Once twisted around the screw clockwise tighten it.
    • Pair the white wire to the silver or light colored screw. Once twisted around the screw clockwise, tighten it.
  9. How to Replace a Three-Prong Plug on a Power Strip: passo 9, immagine 1 di 3 How to Replace a Three-Prong Plug on a Power Strip: passo 9, immagine 2 di 3 How to Replace a Three-Prong Plug on a Power Strip: passo 9, immagine 3 di 3
    • Close up the new plug and screw it tightly shut.
    • Make sure the plug closes well with the cables and it is not blocking the closing mechanism.
  10. How to Replace a Three-Prong Plug on a Power Strip: passo 10, immagine 1 di 3 How to Replace a Three-Prong Plug on a Power Strip: passo 10, immagine 2 di 3 How to Replace a Three-Prong Plug on a Power Strip: passo 10, immagine 3 di 3
    • Seal the Heat Shrink Tubing by holding the flame of a lighter directly on the tubing, moving it back and forth until the tubing molds itself to the wires.
    • Do not let the flame linger for too long, or you run the risk of ruining the seal.
    • If heat shrink is unavailable, electrical tape works just as well.
  11. How to Replace a Three-Prong Plug on a Power Strip: passo 11, immagine 1 di 2 How to Replace a Three-Prong Plug on a Power Strip: passo 11, immagine 2 di 2
    • Connect to the wall and enjoy your restored power strip.
Conclusione
Altre 2 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 38
Tutti i Tempi: 3,321
