Salta al contenuto principale
How to Replace a Penny Board Wheel
Ellie Walsh
Ellie Walsh e 3 altri collaboratori
Ultimo aggiornamento il May 9, 2023
5 minuti
Molto facile
Introduzione
Vai al passo 1
The wheels on a Penny board are what makes the skateboard functionable. It is an essential part of the board. Usage wears the wheels and causes them to lose their grip, smoothness, and functionality. Products are usually expected to be replaced from being used for a long period of time or from just sitting with no usage. This guide will introduce simple steps to replace worn out wheels from a Penny board and will allow you to have a smooth ride. For this repair, a socket wrench with a 13mm hex socket nut is required.
  1. How to Replace a Penny Board Wheel, Wheel: passo 1, immagine 1 di 1
    • Use a 13 mm socket wrench to unscrew the axel nuts.
  2. How to Replace a Penny Board Wheel: passo 2, immagine 1 di 2 How to Replace a Penny Board Wheel: passo 2, immagine 2 di 2
    • Remove the axle nut and the washer from the axle.
  3. How to Replace a Penny Board Wheel: passo 3, immagine 1 di 1
    • Remove the wheel.
  4. How to Replace a Penny Board Wheel: passo 4, immagine 1 di 1
    • Put the new wheel on the axle.
  5. How to Replace a Penny Board Wheel: passo 5, immagine 1 di 1
    • Replace washer on top of the axle.
  6. How to Replace a Penny Board Wheel: passo 6, immagine 1 di 1
    • Place the axle nut on to the axle.
  7. How to Replace a Penny Board Wheel: passo 7, immagine 1 di 1
    • Place the 13 mm socket wrench on top of the axle nut and tighten.
Conclusione
To reassemble your worn out wheels, follow these instructions in reverse order.
Ellie Walsh
Membro da: 02/01/23
145 Reputazione
1 Guida realizzata
UC Davis, Team 3-6, Andersen Winter 2023 Membro di UC Davis, Team 3-6, Andersen Winter 2023
UCD-ANDERSEN-W23S3G6
3 Membri
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 15
Tutti i Tempi: 355
