Salta al contenuto principale
How to Replace Scott Mountain Bike Handlebars
Sean Slater
Sean Slater e 4 altri collaboratori
Ultimo aggiornamento il March 3, 2017
30 - 45 minuti
Moderato
Foto Azione
Introduzione
Vai al passo 1
Need to replace the handlebars on your mountain bike? This guide will show you how to replace it so the bike is good as new.
  1. How to Replace Scott Mountain Bike Handlebars, Scott Mountain Bike Handlebars: passo 1, immagine 1 di 2 How to Replace Scott Mountain Bike Handlebars, Scott Mountain Bike Handlebars: passo 1, immagine 2 di 2
    • Prop bike upright
    • Unscrew the hex bolts holding the front and rear shifter in place.
    • Use the H4 size hex wrench
    • Repeat for other side of handlebars.
  2. How to Replace Scott Mountain Bike Handlebars: passo 2, immagine 1 di 1
    • Slide the shifters toward the center of the handlebars so there is a gap between them and the grips.
  3. How to Replace Scott Mountain Bike Handlebars: passo 3, immagine 1 di 1
    • Use a flathead screwdriver to wedge a gap between the grip and the handlebars.
    • Twist grip around until it comes off of handlebar.
  4. How to Replace Scott Mountain Bike Handlebars: passo 4, immagine 1 di 1
    • Slide the shifters off of the end of the handlebars.
    • Let them hang on the bike.
  5. How to Replace Scott Mountain Bike Handlebars: passo 5, immagine 1 di 1
    • Unscrew the hex bolts holding the center bracket in place.
    • Use H3 hex wrench.
    • Place center bracket and hex screws off to the side. They will be needed in the next step.
  6. How to Replace Scott Mountain Bike Handlebars: passo 6, immagine 1 di 1
    • Attach new handlebars and screw the center bracket back in place.
    • Make sure that handlebars are centered.
  7. How to Replace Scott Mountain Bike Handlebars: passo 7, immagine 1 di 1
    • Slide the shifters back onto the handlebars so that the numbers are upright.
    • Do not screw them back in place yet.
  8. How to Replace Scott Mountain Bike Handlebars: passo 8, immagine 1 di 1
    • Slide the handlebar grips back onto the ends of the handlebars.
    • Slide the shifters back against the grips and screw them into place.
Conclusione
By following these steps, you will have your bike ready in no time.
Sean Slater
Membro da: 02/24/15
139 Reputazione
1 Guida realizzata
Cal Poly, Team 23-3, Green Winter 2015 Membro di Cal Poly, Team 23-3, Green Winter 2015
CPSU-GREEN-W15S23G3
6 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,850
