Salta al contenuto principale
Coffee Table Metal Drawer Slides Replacement
Jaley F Scott
Jaley F Scott e un altro collaboratore
Ultimo aggiornamento il 1 lug 2025
15 - 30 minuti
Moderato
Introduzione
Vai al passo 1
Drawers are very important items in a household. They are used for holding various items. Overtime, drawers can become old and worn down. This leads them to stop working properly, jamming or not closing and opening smoothly.
This guide will show you how to replace metal drawer slides, specifically on a coffee table.
IMPORTANT! Before proceeding:
  1. Make sure to measure the old drawer slides and the drawer insertion to have the correct size for the new metal drawer slides
  2. Make sure to have the correct size screwdriver and/or drill bit/bits
Replacing drawer slides is an easy and effective process. This can save people time and money instead of replacing the whole drawer itself or a whole item that contains a drawer.
Cosa ti serve
Strumenti
Mostra di più…
  1. Coffee Table Metal Drawer Slides Replacement, Metal Drawer Slides: passo 1, immagine 1 di 2 Coffee Table Metal Drawer Slides Replacement, Metal Drawer Slides: passo 1, immagine 2 di 2
    • Make sure to empty the drawer completely before starting the replacement process.
  2. Coffee Table Metal Drawer Slides Replacement: passo 2, immagine 1 di 3 Coffee Table Metal Drawer Slides Replacement: passo 2, immagine 2 di 3 Coffee Table Metal Drawer Slides Replacement: passo 2, immagine 3 di 3
    • Remove the drawer carefully by pulling it out and slowly lifting it upwards until it is out.
  3. Coffee Table Metal Drawer Slides Replacement: passo 3, immagine 1 di 2 Coffee Table Metal Drawer Slides Replacement: passo 3, immagine 2 di 2
    • The drawer and drawer insertion should now look like this when the drawer is out completely.
  4. Coffee Table Metal Drawer Slides Replacement: passo 4, immagine 1 di 2 Coffee Table Metal Drawer Slides Replacement: passo 4, immagine 2 di 2
    • Remove the old gliders by taking the screwdriver and turning it counterclockwise (to the left) until the screw is completely out.
    • Make sure to take out all of the screws on the old gliders before proceeding to the next step.
    • The drill can be used instead of the screwdriver if wanted.
  5. Coffee Table Metal Drawer Slides Replacement: passo 5, immagine 1 di 2 Coffee Table Metal Drawer Slides Replacement: passo 5, immagine 2 di 2
    • This is what the old drawer slides will look like when taken off completely.
  6. Coffee Table Metal Drawer Slides Replacement: passo 6, immagine 1 di 2 Coffee Table Metal Drawer Slides Replacement: passo 6, immagine 2 di 2
    • Measure the new drawer slides.
  7. Coffee Table Metal Drawer Slides Replacement: passo 7, immagine 1 di 2 Coffee Table Metal Drawer Slides Replacement: passo 7, immagine 2 di 2
    • Measure the drawer and the drawer insertion and make sure that the new drawer slides will fit before proceeding to the next step.
  8. Coffee Table Metal Drawer Slides Replacement: passo 8, immagine 1 di 2 Coffee Table Metal Drawer Slides Replacement: passo 8, immagine 2 di 2
    • If applicable, make new markings with the pencil if there needs to be new holes made for the new drawer slides.
    • The drill needs to be used if making new holes for the drawer slides.
  9. Coffee Table Metal Drawer Slides Replacement: passo 9, immagine 1 di 2 Coffee Table Metal Drawer Slides Replacement: passo 9, immagine 2 di 2
    • Make sure everything is lined up nice and neatly.
    • Proceed to screw on the new slides by turning clockwise (to the right) and make sure they are nice and screwed in completely.
  10. Coffee Table Metal Drawer Slides Replacement: passo 10, immagine 1 di 2 Coffee Table Metal Drawer Slides Replacement: passo 10, immagine 2 di 2
    • If applicable, take the pliers and use them to help place the screw in place for screwing.
    • This step is optional.
  11. Coffee Table Metal Drawer Slides Replacement: passo 11, immagine 1 di 2 Coffee Table Metal Drawer Slides Replacement: passo 11, immagine 2 di 2
    • Use the level and make sure the drawer slides are level before proceeding to the next step.
  12. Coffee Table Metal Drawer Slides Replacement: passo 12, immagine 1 di 3 Coffee Table Metal Drawer Slides Replacement: passo 12, immagine 2 di 3 Coffee Table Metal Drawer Slides Replacement: passo 12, immagine 3 di 3
    • The new drawer slides will look like this when put on completely.
    • The drawer slides on the drawer itself should have the wheels placed on the back.
    • The drawer slides in the drawer insertion should have the wheels placed in the front.
  13. Coffee Table Metal Drawer Slides Replacement: passo 13, immagine 1 di 3 Coffee Table Metal Drawer Slides Replacement: passo 13, immagine 2 di 3 Coffee Table Metal Drawer Slides Replacement: passo 13, immagine 3 di 3
    • Put the drawer back into the drawer insertion by aligning the wheels of each drawer slide.
    • Insert at an angle while slowly pushing the drawer downwards until it is completely in.
    • Make sure that the drawer is opening and closing smoothly.
Linea Traguardo
Preparati per le riparazioni future
Acquista tutti
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 41
Tutti i Tempi: 59
