Salta al contenuto principale
How to Replace Keys on a Keyboard
Cooper
Cooper e 5 altri collaboratori
Ultimo aggiornamento il 16 set 2024
10 - 20 minuti
Facile
Introduzione
Vai al passo 1
Do you have a keyboard with keys that do not work? Use this guide to replace your keys and return your keyboard to proper working condition.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. How to Replace Keys on a Keyboard, Individual Keys: passo 1, immagine 1 di 2 How to Replace Keys on a Keyboard, Individual Keys: passo 1, immagine 2 di 2
    • Loosen the key by prying all four corners gently with your spudger.
    • Make sure your keyboard is unplugged before performing any of these steps.
  2. How to Replace Keys on a Keyboard: passo 2, immagine 1 di 2 How to Replace Keys on a Keyboard: passo 2, immagine 2 di 2
    • Wedge the tip of the spudger under the bottom of the key and carefully lift up until the key pops loose.
    • If the key will not come out, or seems like too much force is needed, try step one again.
  3. How to Replace Keys on a Keyboard: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Use tweezers to remove any contaminants that were preventing the key from being pressed down from the now open hole on your keyboard.
    • Do not to grab the actual button, as breaking that could damage your keyboard permanently.
  4. How to Replace Keys on a Keyboard: passo 4, immagine 1 di 1
    • Clean your keys with compressed air by blowing around the removed key.
  5. How to Replace Keys on a Keyboard: passo 5, immagine 1 di 2 How to Replace Keys on a Keyboard: passo 5, immagine 2 di 2
    • Push in the clean keys until you hear a popping sound.
    • The keys should click in easily, so if you are having trouble try realigning the key with its hole.
    • If you removed multiple keys, make sure they are in their proper spot and orientation.
Conclusione
Congratulations! You now have a keyboard with fully functional keys!
Altre 7 persone hanno completato questa guida.
Cooper
Membro da: 02/24/15
493 Reputazione
2 Guide realizzate
Cal Poly, Team 24-6, Green Winter 2015 Membro di Cal Poly, Team 24-6, Green Winter 2015
CPSU-GREEN-W15S24G6
4 Membri
15 Guide realizzate
2Commenti sulla guida
This is How to CLEAN keys, not replace them. Duh.
Mike Miller - Replica
I came looking for how to replace the problematic ones like + on numpad :<
Eskalina Cvrnkalikova - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 105
Tutti i Tempi: 19,025
