Salta al contenuto principale
How to Repair a Warped Cooking Pan
angieaguirre
angieaguirre e un altro collaboratore
Ultimo aggiornamento il June 4, 2024
20 - 25 minuti
Molto facile
Introduzione
Vai al passo 1
Frequent use and storage of cooking pans can cause them to warp and deteriorate over time. Cooking pans can last for years when they’re given proper care. If you happen to accidentally damage your cooking pan, the tools and steps included in this repair will help salvage your pan. Once you have finished your repair, please store it in a safe location to prevent future damage.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. How to Repair a Warped Cooking Pan, How to Repair a Warped Cooking Pan: passo 1, immagine 1 di 1
    • Locate the hard surface you will use for the repair.
  2. How to Repair a Warped Cooking Pan: passo 2, immagine 1 di 1
    • Place one of the two towels on top of the hard surface.
  3. How to Repair a Warped Cooking Pan: passo 3, immagine 1 di 1
    • Turn on the stove to medium heat to warm up the bottom of the cooking pan that is warped.
  4. How to Repair a Warped Cooking Pan: passo 4, immagine 1 di 1
    • As soon as the pan is warm or hot to the touch, quickly remove it from the stove.
    • Turn off the stove and place the pan, bottom up, on top of the towel that is placed on the hard surface.
  5. How to Repair a Warped Cooking Pan: passo 5, immagine 1 di 2 How to Repair a Warped Cooking Pan: passo 5, immagine 2 di 2
    • Place the second towel on top of the bottom of the pan that is facing upward.
  6. How to Repair a Warped Cooking Pan: passo 6, immagine 1 di 1
    • Place the block of wood on top of the second towel that is placed on the pan.
  7. How to Repair a Warped Cooking Pan: passo 7, immagine 1 di 2 How to Repair a Warped Cooking Pan: passo 7, immagine 2 di 2
    • Carefully hammer directly onto the block of wood.
    • Make sure that the block of wood is still firmly on top of the bottom of the pan. This will help ensure that the pan is repaired properly.
  8. How to Repair a Warped Cooking Pan: passo 8, immagine 1 di 1
    • Your cooking pan should no longer be warped. You are finished!
Linea Traguardo
angieaguirre
Membro da: 02/21/24
157 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 144
